Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
Brake wire for Jensen VM9311ts
Cant figure out the brake wire on my 99 Lincoln Town Car.Theres two light green wires by the brake pedal. One w/ red stripe and one thats solid light green. Which wire do I connect the pink wire (from Jensen VM9311ts) parking brake wire to?
    Genius:
  • 1,139 Answers
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Posted on Sep 21, 2007
SOURCE:
My tail lights work blinkers work and flashers work but no brake lights
Will it allow you to remove it from park when the pedal is depressed, ie is the brake interlock functioning?
Mar 18, 2013 | 1999 Lincoln Town Car
Can't shift out of park
This might work for you guy's replace the brake light switch
Easy step by step tutorial watch the video. im sure it will help.
MERCURY MARQUIS STUCK IN PARK
http://youtu.be/fgUn1TuHu-0
Dec 24, 2011 | 2000 Lincoln Town Car
1998 Lincoln Town Car Signature. Parked it and now will not come out of park, and brake lights do not light up. Running lights, turn signals, hazards all work.
you have to press the brake pedal for your car to shift from park.what this does is actuate a solenoid on your steering column with the same electrical signal that lights your brake lights. since you have no brake lights either, all you have to do is replace the brake light fuse and you should be back in buisness.
Oct 18, 2011 | 1998 Lincoln Town Car
I have a 99 harley ultra classic. the rear tail light has 3 wires, black, red and blue. the black i figure is ground cuz it was grounded on the oem tali lamp, but the blue and red i cant figure out. i have...
I would suspect that the black is still ground and the red goes to the red from the bike and that the white is for brake switch when you press the pedal or lever. Hook it up that way and see what you get. Good luck.
HDTV GURU JAY
Mar 16, 2011 | 2003 Harley Davidson FLHR Road king
My brake lights are not working at all. The fuses are not blown
Hi!!
Check the Brake Pedal Position Switch on top of the brake pedal, the Lt Green w/Red stripe wire should always have 12v+, when brake pedal is depressed the Lt Green wire should have 12v+ also, if no power on Lt. Green w/Red wire, check fuse # 2 20A, if no power on Lt. Green wire when pedal depressed, REPLACE Switch, If there is power on both wires when pedal is depressed, check IVD STOP LAMP RELAY on the Aux. Relay Box 1 located at the Left Front of the Engine Compartment.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 16, 2011 | 2003 Lincoln Navigator
In order to put my 1994 lincoln towncar in gear i have to turn the ignition and gear stick at the same time. then the stick is pulled into neutral then i can start car and put in drive..whats wrong with my...
Sounds like the "shift lock actuator". It's a common Ford/Lincoln problem. It's basically a safety device to ensure the car is turned on and your foot is on the brake b/4 you can place the car into gear. Here is a gr8 piece describing the problem
" This is a problem with the Shift Interlock System and not the transmission. Bet you're glad to hear that. The Shift Interlock System requires the key to be in the "RUN" position and the brake pedal depressed in order to shift out of "PARK". This is to prevent possible vehicle runaway. There are a couple of possibilities here. The first is the Brake Pedal Position (BPP) switch. You can usually tell if this is bad if you have no brake lights at all. Another possibility is a bad Shift Lock Actuator or Shift lock solenoid, located under the console.
First thing to do is check fuses 28 and 32 in the fuse box, if you haven't already done so, and make sure they are good.
78584194.gif To check the BPP switch, check for power at the light green/red and light green wires with a test light with the key in the "RUN" position and the brake pedal depressed. If you have power there, then check for power at the light green wire at the Shift Lock Actuator.
78185284.gif f you have power at the light green wire at the Shift Lock Actuator, ground the black wire. If you hear a click, then you have a bad ground and it needs to be repaired. If not, the Shift Lock Actuator is bad and needs to be replaced."
I hope this give you a better understanding and I wish you the best of luck with your problem.
May 06, 2009 | 1994 Lincoln Town Car
1999 Lincoln Town Car shifter stuck in park
Look at the swith on the brake pedal, it shoud have two green wires on it. Make sure it is not melted or the wire is broken. If it is damaged you can connect the 2 wires together to get it into gear, but this should be temporary as it bypasses the neutral safety switch.
Apr 16, 2009 | 1999 Lincoln Town Car
Brake lights
Check the wires and connector at the brake pedal switch. These wies have a tendency to break, This will cause no brake lights amd not allow the shift interlock to function
Dec 28, 2008 | 1998 Lincoln Town Car
Jensen vm9311ts car tv
ground green pink wire
problem fixed
Feb 10, 2008 | Jensen VM9510 Car DVD Player
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
197 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
