Question about Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M35X-S161 will not start up...lights come on but no power up???
This seems to be a common problem but I do not see a common answer. However, when I turn my laptop on the power button will light up and the LED's on the front will come on, but there is nothing on the screen (remains dark)..plus the fan comes on but in 5 seconds or less the fan stops, the unit stops "booting" at that point and the leds's and blue power button remain on. Occasionally (maybe 1 out of 100 times) it will power up but it seems that the few times it did come on I moved it and it went of...but one of the times it was on I shook it a bit to try and determine if a loose wire was the cause and I figured it would cut off when I moved it but it did not????????? I am strapped here...out of warranty, no close service experts, nothing...any help would be A-1. thanks in advance-rick
  • Anonymous Nov 04, 2007
    I have the the same problem. So whats the fix?
  • rguea Mar 02, 2009
    No power-up...blue power light,fan.a/c led and battery led come on but nothing else. Display is black and computer never boots.
    Scholar:
  • 181 Answers
Hi, Toshiba extended the warranty of the M35 till Nov. of this year for this same problem. If you just contact Toshiba support, they'll rplace the board no charge. I've had a few repaired. They only take a few days. Good luck,
Posted on Sep 21, 2007
  • shottz200537 Mar 09, 2011
    shut it off -hold zero then turn machine back on-warning screen say yes-delete files and partitions say yes-delete files and overwites option say yes-will take 12 hours so leave in a good spot itll say finish then press finish-restart-*black scree*-shut off computer again-hold zero then turn computer back on- warning screen say yes-restore to factory(option above delete files)then continue to to follow directions to restore to factory condition..will go completely back to factory.
Several model Toshibas had this problem includint M35X and M75X. There is a small power chip under the top cover bezel(above keyboard) that overheats and comes off the MB. Some say heating it will reseat the IC but others replace the board. It is a design flaw that is why Toshiba extended the warranty. Good Luck!
Posted on Sep 03, 2012
Where do you insert the hard drive in a toshiba satellite m35x-s161?
Fip it up side down, look at lap top rear on your right, remove screw just before footing, slide out the HD adapter/bracket.
Oct 22, 2010 | Toshiba Satellite M35X-S161 Notebook
I have a toshiba Satellite M35X-S161 notebook. It needs a new hard drive. Do is use an IDE or SATA and how large can it be. It has a 60g now. Is it easy to change.
This will take any EIDE disk, read not SATA!! It is very simple to replace a disk. It is a challenge to reload the OS and the drivers. Before you start, make sure you have the recovery disks or an XP disk. In the process, all of your data will be lost unless it is backed up someplace.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 03, 2010 | Toshiba Satellite M35X-S161 Notebook
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
My toshiba m35x-s161laptop has issues
may be the procesor unit(cpu) is too bot because a dust.....
Mar 06, 2010 | Toshiba Satellite M35X-S161 Notebook
I have a Toshiba Satellite M35X-S161 that will not stay turned on for longer than 15 minutes.
Check power management - clean dust from fan - full system virus/spyware/registry scan. Place external fan to help internal fan.
Apr 04, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba M35X-S161 motherboard replacement issues
How to remove back cove rof my Toshiba M35X-S161 to get the charging input jack to repair it?
Mar 28, 2009 | Toshiba Satellite M35X-S161 Notebook
Tashiba Satellite M35X S161 AC Intermittent Power Problem.
Your model of laptop is typical for the issue of the power plug. The plug can be soldered back on. As far as compatible memory you can call toshiba customer support and they probably could answer that question. there # is 1-800-457-7777
Mar 07, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba M35X S161 Ribbon Connector
You can buy another one cheap at a computer retailer, maybe. Search eBay too. There are various good things available there.
Nov 30, 2008 | Toshiba Satellite M35X-S161 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
853 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
