Question about Coleman Heating & Cooling
We have a rooftop coleman air conditioner on our RV. When it runs it trips water on the counter top instead of draining on the roof. I don't know how to fix it
    Guru:
  • 588 Answers
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on Aug 02, 2009
Water is setting in the air box and coming out onto counter.
find the drain line and blow out from either top or bottom, spiders love to web in them
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
Jun 28, 2014 | Dometic Rooftop RV Air Conditioner
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Coleman RV roof air
I think you have a high pressure switch that has tripped. open up the case and look for a switch connected to the line with a resettable button in the case it is not resettable you will have to have a professional replace it. If you are able to reset it make sure to clean the condensing coil on the top side before running it again as most likley this is what may have caused it to trip.
Jun 22, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach roof top ac
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
Coleman RV air conditioner
It is not leaking. that is the condendensation it is pulling out of the air. It is suppose to leak on the roof and off the camper.
Oct 06, 2007 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
368 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
