Question about Foxconn P4M9007MB-8RS2H Motherboard
Operating system not found( hp pavilion laptop)
new hard drive fitted and still get same message
    Sergeant:
  • 150 Answers
Try to reformat and reinstall the os
Posted on Apr 20, 2009
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 18, 2010 | HP Pavilion dv6000z Notebook
Can I replace orig hp ze1115 20GB hd w/60GB hd?
No the bios should be able to read the drive fine. The problem could be with the computer's motherboard. You should check to see if the original drive and new drive is detected in another system. Or you can try accessing them via an external casing / adapter.
May 25, 2010 | HP Pavilion ze1115 Notebook
Loud humming noise, then went away. hp told me to remove hard drive then reinstall, now have no bootable device message???
your hard drive has died. replace hard drive and re-install operating system.
hard drives only last up to 5 years. guaranteed to fail eventually.
Nov 26, 2009 | HP Pavilion dv4000 Notebook
I bought a HP Pavilion ze4300 laptop and it has Windows XP on it and it was working fine for the past three weeks. Yesterday I started it up and am getting a message: ''Operating System not found''. One of...
It could also be the conncetion came loose, which can happen with IDE hard drives if the laptop gets moved around a lot. Remove the hard drive and take it to an electronics store to have it tested, or if you have a friend with an external enclosure (2.5" IDE interface, they cost between$10-20) you can hook it up to another computer via the USB port
Sep 25, 2009 | HP Pavilion ze2000 Notebook
My hp pavilion 4200 i took the hard drive out and put it back in when i booted it up it says media cable not found then it says operating system not found. tried to run the operating system cd and it says...
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
Mar 08, 2009 | HP Pavilion ze4200 Notebook
Hi,? my machine has an error of loding operating system it's hp 530,it brings this informationn (no hard drive were found ,so it is not detectiting any hard dirve installed.
The most likely explanation is that your hard drive has failed. You can try removing and reseating it. Failing that, borrow one for testing or buy a new one. As a last resort, try putting the hard drive ( or even the whole laptop ) in the refrigerator overnight. Really! :) If this restores operation even temporarily you definitely have a bad hard drive.
Jan 01, 2009 | HP Pavilion dv6000z Notebook
Ze5185 operating system not found
Could be a sign that hard drive is failing or a problem with Windows. Do you hear any strange noises, clicks?
Try re-installing Windows and see if that helps.
Thanks!
Mar 24, 2008 | HP Pavilion ze5185 Notebook
Foxconn P4M9007MB-8RS2H Motherboard Logo
196 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
