Question about Samsung PCH521R 52" Rear Projection Television
52" Samsung rear projection TV
When we turn the tv on first thing in the morning it takes longer and longer for a picture to appear. It started out approx 15 minutes now it is over an hour. When the picture does come on it does it all at once. Appears that it does not get enough power. Have already replaced it but if an expensive fix would repair for the basement.
    Genius:
  • 1,694 Answers
Check for CRT coolant leak on PCB's.If minor, clean up spill--try again--see what you have.
Posted on Oct 04, 2007
SOURCE:
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung rear projection tv wont turn on.
Replace your STK ics both of them. STK392-040 go by number on parts
Nov 15, 2008 | RCA D52W19 52" Rear Projection Television
Samsung 52" tv
you could possibly have damaged the deflection power supply that part is not to expensive if you can find a reputable shop they should be able fix you up pretty cheap as opposed to a new. if the set had a good picture get it fixed its a good set
Jun 11, 2008 | Samsung HC-P5241W 52" Rear Projection...
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
Samsung PCH521R 52" Rear Projection Television Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
