SOURCE: Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
SOURCE: WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
SOURCE: Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
SOURCE: How do I completely remove the WD Sync software
HOW TO BYPASS THE CRAPPY SOFTWARE
1. Install WD Smartware and update it.
2. Run Virtual CD (VCD) Manager at http://www.wdc.com/wdproducts/updates/?family=wdsmartwareutilities
to remove the virtual CD drive.
3. Use Control Panel add/remove programs to uninstall WD Smartware.
4. Everytime When you plug the hard drive in Windows will come up with the look for drivers window hit 'Cancel'
5. Now use it as an ordinary hard drive!
