Question about NEC MT1060 Multimedia Projector
Turn on green, beeps 3 times then red, orange lights flashing
The projector turns on status light flashes 12 times then beeps 3 times then red, orange lights flash then the project turns off and lights keep flashing. No image.
NEC MT1060 LCD projector (about 6.5 yrs old): image was getting dim; now when turned on it makes a "dialing" sound and the green power light turns to a flashing red and orange lights. I thought I saw some smoke and I cut the power just in case.
SOURCE: NEC MT1050 pojector
you are right about the filters. It turned out that the projector was slightly damaged and there was a filter trigger that was not being pushed in and was not allowing my projector to turn on. Had to have that disconnected by a professional so that the projector would work.
Posted on Jan 15, 2008
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
SOURCE: No Picture on my nec VT676 model
Thanks. NEC did not have a solution for us, but the solution for us was to replace the bulb. You'd think they would make that a bit more obvious!
Thanks.
Posted on Mar 27, 2008
dhiman
  • 115 Answers
SOURCE: lamp not lighting
Reset the lamp and try it.
Posted on Mar 29, 2008
  • 6 Answers
SOURCE: No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
Posted on Aug 31, 2009
5738 status light blinks red 5 times then orange 7 times
if it is a 7 then u must replace.
SOURCE: i am a mechanic
Jan 21, 2012 | Mitsubishi WD-65738 DLP TV
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
Mar 18, 2011 | NEC VT595 LCD Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
May 28, 2009 | NEC VT465 Multimedia Projector
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
NEC MT1060 Multimedia Projector Logo
2,131 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
