Question about D-Link DI-704P Router
Can't Ping D-Link Di-704P
I cannot ping the device via 192.168.0.1 Has this device gone belly up?
    Brigadier General:
  • 6,966 Answers
Hi, A couple of things you can try: 1. verify that your LAN cable from router to PC is good. There should be some indicator LEDs lighting up when connected/linked; 2. Co to Start, Control Panel, right click on your Local Area Connection, Properties, highlight Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address > IP address 192.168.0.254; Subnet mask 255.255.255.0; Default gateway 192.168.0.1, OK; 3. Check if you can ping 192.168.0.1; 4. If not, you may need to do a hard reset your router. Pls be reminded that all configurations on the router would be reset to default; 5. If the reset does not work, then perhaps the router would need replacement. Hope this be of some idea/help. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 21, 2007
Staus led not blinking after a fw update
You are going to have to find a software that helps you force reinstall the Firmware. Something went wrong somewhere, I know the software exists, i used it to install a 3rd Party Firmware on my linksys to gain Access Point Functionality
Apr 14, 2010 | D-Link AirPlus DI-524 Wireless Router
Unable to ping static IP from remote desktop when
Does PING works on the same location where Camera's are located?
Usually, RDP connections uses the same PC on LAN and that should work fine. Please check Camera's configuration; make sure they have valid IP address, SM, Default gateway and DNS servers. Make sure that PC with enabled RDP can PING computers on the LAN either by IP address or Computer name. Make sure they're part of the same WORK GROUP.
Hope this helps! Please provide additional information so I can further assist you.
Mar 28, 2010 | D-Link DI 514 Wireless Router (DI-514)
I cant access router ip address
You must make sure that your PC get connection with the router first. you must enter on the command prompt.
1st step- click start, go on run.
2nd step- type "cmd", there will be a black window which will opened.
3rd step- write "ipconfig", there will be a default gateway given just below the subnet mask.
4th step- write ping then the default gateway; for example: "ping 192.168.0.1". if is is replying, your PC get connection with your router. But if not there may be a problem with your cable or something else. then your can try to make a reset no your router. there is a reset button at the back of the router.
Feb 07, 2010 | D-Link DI-704P Router
I can't get to http://192.168.0.30
Is this the IP address of the router or computer.
When you open the command prompt, try to ping that number and check if you get replies.
If you are trying to access the router then make sure that you are using the default gateway number.
Click here for more info about routers and networks
Jan 14, 2010 | D-Link DI-704P Router
D-Link DI-704P as wireless
Yes, you have to. The router model mentioned is not a wireless router, not unless you have other network device there that transmits wireless connection such as a wireless access point.
Jul 05, 2009 | D-Link DI-704P Router
Client PC not able to ping WAN networks
Did you set reverse routing rules on the D-Link?
Dec 18, 2008 | D-Link DFL-800 Firewall
Problom
well....don't keep us in suspense...finish the rest of the story...c'mon....Don't do this to us!!!
Feb 12, 2008 | D-Link DI-704P Router
DI-Link model DI-704
I have the same problem... my connection after an hour will slow down but after i turn off and on the router again, my connection will back to normal again... Can u please help... thanks.
Dec 09, 2007 | D-Link DI-704P Router
No amber light
I think ya gonna find ya modem has gone "toes up"... It may well be in the power supply section (PSU)... I guess ya could try a "Shotgun" replacement of all the PSU components.. If this don't "Fix" it.. then I am sorry but ya up for a replacement.. which may be the best option in any event?
Aug 30, 2007 | D-Link DI-704P Router
Sympatico & DLink DI-704P
It usually is simple, and hopefully the answer is as well. If you haven?t already done so unplug the modem and the router. Wait for a few seconds and then plug the modem in followed by the router. Reboot your PC and try the Internet again. If it still doesn?t work then I would try doing a hard reset of your router and reconfigure using the setup process outlined by the manufacturer. If that still doesn?t work let us know and we?ll continue ?.
Jan 01, 2007 | D-Link DI-704P Router
D-Link DI-704P Router Logo
857 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
