50 plasma tv
I have had my tv for two years now,just yesterday it sounded like a breaker popped and the tv went down, it was warm, i let cool down and turned it back on, guess what the sound worked but no picture, is it junk now or how to fix
  • 6 more comments
  • Anonymous Sep 25, 2007
    i have read on another answer that the power supply was bad, i have it pdp50 akai, i have the sound but no picture , please one of you masters help
  • Anonymous Sep 26, 2007
    i have read that other akai tv have had similar problems,with the power supply , is the power supply the same for a 50 tv compared the the 42
    was hoping for more of an answer, i have read the 42 inch akai has the same problem i have the part number for that , do you think that is my problem too, and is it the same part number if not do you know what the number is for a pdp 50 inch, thanks
  • Anonymous Oct 15, 2007
    the tv technician guru was helping me with this tv, i hope you read this, i opend up the back is says samsung all over the other boards, but the power board does not have a name on it but it has numbers mpt012a made in china of course, do you know where i can get one thanks
  • Anonymous Oct 16, 2007
    hello again and thanks for getting back with me so soon , here is what i found, from where you plug it in, it goes to a small board that is differennt color than the others it says ac in and ac out with no other numbers on it, the other two bigger boards in the middle of the tv are lj 4400057a      and     lj 41 02458a     i hope this helps   thanks   jeff
    the model is s50hw-xbo2,     the other boards in the middle of the tv i found the numbers lj41 01810a,,,     and lj4400057a       and lj41 02458a,     ,  the board that the 120 v supply board i checked out it has 120 in  and 120v out and three of the four terminals of the dc i get 17 volts should i be getting 17 volts on all four  thanks again
  • Anonymous Oct 17, 2007
    i would like to thank you for being so much help,people like you are awsome, my email is [email protected]
  • Anonymous Oct 18, 2007
    this manual has been gread help in understanding the layout, but i only have the basic tools here like a multimeter , so bear with me , i really didnt see where to check the vs and va voltage so if you could give me a quick tip, and also on the led lights the 8001,8003 and 8004 lights did come on and the red 8002 never did come on, thanks again
  • 105 Answers
If you have the tv opened can you see a samsung sticker on the back of the plasma panel. if so i need the panel number. then i can give you correct part number
Posted on Oct 13, 2007
  • 1 more comment
    if your looking on the board itself youll see a lj92-???? or LJ41-???? number. this number will also help me with part number
    what is the tv model number
    perfect thats what i need to know. send me your email addy to [email protected] and i will email you a manual that will be great help to you. your tv is the same as s50hw-xd03 in this manual. the only way to know for sure your power supply is bad iss to check the vs and va voltages. the large board in the top middle is the smps( also known as power supply). you will see a wire harness with one black wire and the rest white going to a board on the left side. check to see if you have your vs and va voltages heare. if they are there you will need to replace the y sustain board. if you dont have them then you will need to replace the smps. the manual i am going to email you has all the part numbers
  • 752 Answers
It is repairable (or should be). It's not something you can do on your own, though. Parts will need to be ordered and replaced. Any repair shop should be able to get you up and running again. Call around for estimates.
Posted on Sep 21, 2007
  • Mitch
    Mitch Sep 26, 2007
    Sorry, i don't know if the supplies are the same for the two different sets.
SOURCE:
50" Insignia plasma made a pop sound
This might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
I heard a pop. The TV went off then when I turned it back on the white has red pixels showing. Seems one of the LCD colors went out. Is there a fix. The TV is jsut over a year old.
This is a plasma tv not lcd. The pop mostlikely was a part on the y main board. IF the y-main voltage shifts the set will have red sparkels.
EBR55360701 All tech depot . com $65.00
Feb 21, 2011 | LG 50PS80 50 in. HDTV Plasma TV
I have a 50 inch plasma vizio tv. I was watching it then i heard a pop the screen went black and i still had sounds yesterday but today no sound, I called vizio tech support they told me it was the gas...
when you here a loud pop its usually the sustainer boards. Have you checked the fuses on the sustainer boards first to see if they are still good. There is a IC chip under the heatsink and when it gets extremely hot it gives. Also check you power supply board to make sure you don't see any swollen capacitors, leaky or bulged out from the top. Let me know if that helps at all.
Oct 26, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
We have a pioneer plasma tv and there was a loud popping sound and then the screen went blank
I had the same thing happen a few weeks ago to my zenith 50" plasma tv. I tried to turn it back on with the remote and the power button on the set but the only thing that happened was the led would flash green 3 times and then go back to red. I took it to a repair shop and they called yesterday to tell me it was going to cost $700 to fix it by replacing the power supply. No guarantees either that it will last any longer than the 3 years I've had it for either. But it's still cheaper than replacing it with a new "bigger" tv which is what I will eventually do anyway. I've heard of people looking on ebay for repair parts and doing the repairs themselves but there is no warranty on human error...
Nov 05, 2009 | Pioneer PureVision Pro-800HD 43 in. Plasma...
LG 50inch Plasma received loud sound then went black
I suggest you guys take your TV's into a repair shop like Sears or Best Buy... The main reason most plasmas go dark is because of decay, but I don't think this is the case. Because what you describe is similar to what happens in LCD's when their back light goes out. Although you can open up and repair the back light your self in a LCD, I would not advise you to do so for a Plasma, because of the hazardous chemicals used in the plasma display plus the fact that plasmas don't use back lighting. And 2 years is way to soon for decay to be a factor. So more than likely a circuit shorted out and the TV has to be opened up to be repaired.
May 27, 2009 | LG 50PX4DR 50 in. Plasma TV
Big POP no sound no picture
if you could see light orange or green is has power is probably teh Y and Z board
Aug 22, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Plasma tv repair question
Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
Started as 1 then 4 over 4 months
Aug 10, 2008 | Televison & Video
LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
Ekse
