Question about Poulan Pro Chain Saw 46cc 20"
Chainsaw has no spark
Check plug installed new coil on unit still no spark
  • randyreese2 Apr 22, 2009
    replaced plug and coil,very light spark, still no start.Is there a certain gap at magneto or something with gas or filter.It only has maybe20 hours on it.
  • 226 Answers
Gaps at magneto are close to business card/newspaper thickness. That's what I use. Hope this helps, Rick
Posted on Apr 25, 2009
New coil weak spark
Hi Bill:on't know what unit you're dealing with, but check to make sure that the coil installation has the correct clearance from the flywheel. Also, try a spark check with a new plug.
May 15, 2015 | Garden
2002 mitsubishi galant 1 and 4 spark plugs no spark ....i need help . . i change the coil and plugs already still no spark..
Look more closely at the 1 and 4 coil, also, check for trigger signal to these coils. I mostly suspect the trigger unit.
Dec 04, 2014 | 2002 Mitsubishi Galant
I have no spark on my 1980 kdx 80 bought a new coil but not sure if that's the issue cause I can feel spark with the old coil but I can't see it any help ??
If you can't see the spark, maybe the gap is set too short?!--Typicaly, with a "no spark" issue, you want to make sure that you have a good spark plug & plug wire/boot. If all those are good, then you need to check your coil...a good coil should test AT LEAST 3.2ohms on a multimeter to provide adequate spark to the plug. If the plug, wire/boot, & coil are all good, then it's a safe bet that you need a new cdi/tci box, as that unit is what sends the signal to the coil to create the spark.
Jun 09, 2014 | Motorcycles
No spark,"Gardentech" (Netto/Aldi) how can I test ignition unit?
no meter needed just take the spark plug out then hook the coil wire back to it, try to find a dark area then hold the spark plug to the head anywhere that's metal and have a friend try to start it or do so yourself with the switch on of course. If it sparks at the end of the plug then the coil is good. If not install new plug , repeat procedure. Also, check all wire connections and ohlm out the switch why your at it.
May 30, 2014 | Garden
Briggs ans Stratton Quantum 5.5 HP still no spark after changing coil and plug
You are correct, you have a flywheel with magnets in, an electronic ignition unit which when the magnets pass the ignition unit core at speed energises and creates a spark via the plug, the earth wire simply takes the unit to ground and shuts off the spark, the unit you changed was it definetly an electronic unit or just a coil? if electronic and you are cranking the engine fast enough and have the plug well earted against the cylinder with the earth wire not connected it should spark.
Sep 01, 2012 | Garden
No spark replaced coil no spark does the low oil have anything to do with no spark oil is up to full line
We use growler to test the coil off the engine. To make sure that other components are not the problem, remove any other wires connected to the coil. Always use a new spark plug for testing. Once you have solved the problem, remove the new plug and put it away for spare. If spark with other wires removed suspect faulty oil sending unit or short in wiring or faulty kill switch (test old coil also). Do not replace sending unit however, just check oil before every use. Good luck
Sep 17, 2011 | Coleman Powermate Powermate 5000W...
I changed the magneto on my Honda GX160 QX2 5.5hp. small engine and I still have no spark. Any suggestions on what to check ?
There could be an issue with the oil sending unit, spark plug boot or faulty on/off switch. Easy tests. Always use a new plug for testing. Unplug the oil sending unit wire and retest for spark. If spark may need to change the oil or low oil. If still no spark, leave the sending unit wire unplugged and remove the boot from the plug wire. Insert a short piece of paper clip wire into the end of the plug wire and hold near metal of the engine for test. If spark, replace boot. If still no spark, unplug wire from on/off switch and retest. If still no spark suspect faulty coil ~ redo all tests using old coil. If still no joy return new coil for exchange. I use a growler to test coils(growler used for testing armature for short, place one leg of coil on each pad of growler and activate growler for short burst). Good luck.
Aug 10, 2011 | Electrical Supplies
No spark
check pulse generators first, i found one burnt and one was open on my 87 hurricane 600. Ohm the wires out for opens or low ohm readings readings,they should be about 400ohms or more. if thats good then check out spark unit..if thats good then check to see if coils wires are getting 12v. Then if that is good check resistance of primary and secondary plug wires. or just replace them anyway and that one less thing to worry about. you have new plugs and wires. it can only really be the coils or pulse generator. hope this get you in the ballpark can iget a helpful on this thanks but if i helped you fix it by checking the pulse generators i'd like a very helpful, appreciate!
Apr 10, 2010 | 1987 Honda CBR 1000 F
Where are the spark plugs located on the car
They are underneath the coils,there will be a coil,and under the coil will be a spark plug boot connecting the coil to the spark plug.
Oct 30, 2009 | 2001 Oldsmobile Intrigue
Gas chainsaw has no strong spark and wont start
the air gap should be .012", the gap you have it set at is to small.reset the gap and try it again.......hope this helps,let me know........
Jun 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
242 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
