Question about Altec Lansing AVS 500 Computer Speakers
Humming noise but no sound
It is attached to a braille display Alva and JAWS program for the blind. after another ill qualified tech person tried to install duxbury on her computer which I am not sure is the cause. I checked her connections to make sure nothing was unplugged I think it is a short in the wiring what do you think?
  • stellam Sep 24, 2007
    thanks so much I will let my friend know and will try checking it again
    Genius:
  • 1,139 Answers
It not a short but it is 60Hz hum coming from the a loose connection to ground (not properly grounded) check your power strip for proper ground, 60HZ hum is the culpurit here.
Posted on Sep 21, 2007
4x4 jeep grand Cherokee sport noise is on driver side not humming or rattling rash be sound
get car serviced, ? (live persons)
we are blind and deaf here,
we can't hear that noise.
the only man hear that can guess good here, is this man.
http://www.screeninsults.com/images/the-tonight-show-starring-johnny-carson-carnac-the-magnificent.jpg
but needs envelope primers. LOL !
only moving?
when? in 4wd only?
location is #1, exact locations.
can just be brake pad warning, devices. Normal for bad brakes.
finding moving only noise is dangerous, lacking the correct tools.
http://www.fixkick.com/NOISE.html
end.
Sep 23, 2015 | Jeep Cars & Trucks
Car will not start and when key is on making a humming noise. what is that?
Could be the fuel pump. Any fuel leaks? If so, stop and see a qualified mechanic.
Is the sound coming from the rear of the car? Open the gas cap and listen at the fuel intake. Is the sound louder? If so, the fuel pump may have a rotted line attached to the fuel pump in the tank.
If he sound is coming from the dash or under the hood it could be a number of other issues.
Nov 05, 2014 | 2006 Nissan Altima
Roland Cube 60 Amp
The power relay must be replaced or checked thats where the humming noise come from.
Jul 05, 2013 | Audio Players & Recorders
I have a Proform 590T treadmill that is 3 months old - about 60 - 75 miles on it and it has become noisy. Not a clunking just a loud hum. It is the same noise regardless if you are walking on it or just...
It might be motor bearings or a roller. Remove the drive belt and run the machine.
Icon has a good warranty program. I am a service tech for the company working in Canada. If it is only 3 months old, call ICON and arrange a service call from a qualified tech.
1-888-533-1333.
Dec 14, 2010 | Proform 590T Treadmill
My image runner 5570 was serviced and now it makes clicking sounds. The clicking doesn't happen while printing. Any idea what the problem may be?
Is the clicking noise when the copier at idle, not making copies? If so, it sounds as if the fuser main drive gear is broken ( cracked ). It happens alot on this model. The part number is FU6-0736-000. This may have to be done by a qualified tech. The break down of the fuser is something a lay person shouldn't try. Good Luck
Nov 04, 2010 | Canon imageRUNNER 5570 Copier
Hampton bay fan noise
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Jun 14, 2008 | Hampton Bay 24002 Ceiling Fan
Celing fan making noise, how to oil
HOWEVER...
Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
Altec Lansing AVS 500 Computer Speakers Logo
99 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
