Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
Can't open the drive
I put in the flash drive, I see the small icon at the bottom come up "Found New Hardware" "Your hardware is ready to use" etc. But I'm not getting an icon to open the drive, and it's not even showing up in My Computer. The info on this drive is very important.
  • Anonymous May 06, 2009
    when i plug it in it blinks orange and then the computer freezes up
  • 59 Answers
Sometimes there is an issue assigning a drive letter. You can try to assign one via right clicking on My Computer and select Manage. Go down to Disk Management and find your USB drive. You can right click it to reassign it a different drive letter, one that is not being used. Hope that helps, let me know if this does not fix it, as there are more steps to try, just a bit complicated.
Posted on Apr 20, 2009
What can i do? my jetFlash V85 is unknown
Connect your flash drive to your computer using an available USB port.
If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive.
A question mark icon should be shown to the left of the label.
Right-click the device name and select "Uninstall."
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes."
This will scan your PC for any new devices.
Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
Click "Start" > "My Computer" and look for your flash drive.
If this process was successful, your flash drive should now show up under My Computer as a storage disk.
If its listed as an unknown device
Then right click on your flash drive select rename
Hope this helps
Nov 08, 2012 | Electronics - Others
I just purchased an 8GB USB 2.0 flash drive from SanDisk Cruzer. I plugged it in, it recognized it then opened to documents what do i do next?
Its now ready to use. You can add any files into your flash drive, use it on any other pc by plugging it in. You can delete the files and add other files if u need.
All that you need to keep in mind is , do 'safely remove hardware'(which can be done by clicking at removable hardware icon located near time in taskbar) option before you remove it physically.
There you go !!!
Regards,
Sreejith
Aug 01, 2011 | Computers & Internet
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hi i bought 160GB 2 years ego now suddenly after 100 times when i was connecting my portable hard to PC i realized WD icon didn't show on "my computer" although "found new hardware "...
The hard drive may be corrupted and you need to format it to made it useable again.
Formatting the hard drive will delete the data on the hard disk.
Apr 15, 2011 | Computers & Internet
How to use toshiba flash drive 2.0
Follow these steps :
1.1
Plug the flash drive into one of your computer's available USB ports.
2.2
Look for the "Found New Hardware" balloon to pop up in your system tray. When the installation is complete, you can either click the balloon or go to "My Computer" and double-click the flash drive to open it.
3.3
Open the folder containing the data you want to store on the flash drive. Either copy the files and paste them into the flash drive's folder, or drag and drop.
4.4
Click the "safely remove hardware" icon. This is an icon with a green arrow in the system tray in the lower right-hand corner of the screen. When you click it you will see a message that reads "Safely remove USB Mass Storage Device." Click that message box.
5.5
If your flash drive has a light, it will turn off when the drive can be removed. Otherwise, it is safe to remove the drive when the message box goes away. Remove the drive.
Oct 29, 2010 | Computers & Internet
Im using 32gb kingston pendrive its a gift so i dont know where thy bought. the Problem is, while inserting it denote as new hardware found later it denoted as hardware missing could u pls suggest me to...
first of all insert ur pendrive correctly n firmly into the usb slot wen the new hardware icon displays u just refresh ur computer by pressing the F5 button on ur keyboard do this nearly 5 times then wait for few seconds; once the new hardware is done installing ur pendrive is visible in "my computer"; double click on the new displayed icon and start using it .
If the above procedure doesnt work 1st time please do repeat it again ur pendrive will work for surelly
Sep 17, 2010 | Electronics - Others
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
A Dummy requires simple instructions/reassurance in connecting/using Micro Cruzer Flash drive with windows XP usb connection.Auto synch??? etc
Just plug it into an available USB port! Wait a few seconds and watch the bottom right of your computer screen for the status. It will tell you that the computer has detected new hardware, that it is some sort of hard drive, that it is installing appropriate drivers, and then finally (30 to 60 seconds later), that your new device is ready to use. Then just double click on "My Computer" (if it is displayed on the desktop), or under the Start menu. There you will see an icon for you new "hard drive". Just double-click on it to open it. Then open another window containing the files you want to copy to the flash drive. Then you can copy stuff to it just by dragging your files from an open window to your flash drive window.
Nov 16, 2009 | Computers & Internet
I have attached pen drive to my pc. it shows the message "New Harware Found" and "Ready to Use". But when i clicked on My Computer It doesn't show the Drive. Please tell me the sol as soon as possible....
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 20, 2009 | Pen Drive IVO MP3 Player
Usb flash drive
It is simple to use, simply plug it into a working USB port on your computer and Windows or Mac will detect it as an external drive device. You will find the new drive under My Computer. The bottom right may display a "found new hardware" or something similar. Once you find your drive, open it and choose what you want to put on it. Just drag everything you need onto the new drive. There is a possibility that you have to format it first. Do do that, just right click on the drive device and choose Format. Use FAT or FAT 32. To remove the USB drive, find Safely Remove Hardware close to the time, right click it and select remove. This is more important on a MAC because data could easily get erased if removed without giving instruction to remove it.
Oct 29, 2007 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
130 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
