Question about Intel Desktop Board D845PEBT2 Motherboard
Computer does not boot
Intel Motherboard D845PEBT2 with 250 GB segate harddrive.
I started a few days ago, when I got a thermal event warning and the computer shutdown. This happened sometime over night so the computer was off for a good two to five hours. After this the computer would go into the boot phase and the fans would churn a few seconds and then shut down.
I noticed that by removing the motherboard power, the fan and hard drive would run but as soon as the mother board power was connected the same thing of a few seconds of churn and then everything stopped.
If I kept the power button pressed on this would go on for little longer time but would not boot.
After multiple attempts over a period of 6 hours, it stated all by itself and ran for a few days and quite a few reboots.
Today, while processing a large/complex photoshop job, the computer shutdown by itself and then at each reboot, when WinXP Pro would start, it would shut down.
I started it in safemode and uninstalled a software (photoshop plugin installed by installer) to make sure that it was not causing any issues.
Now it would not boot at all. No fans, no hard drive, although the motherboard light and the LAN light comes on. But when I try to boot it, no results. Even removing the motherboard power cable does not help. Still no activity.
On strange thing I notice is that my room light dips (flickers) a bit when I turn the computer on. This could be a power supply issue. Or could the CPU have been damaged due to over heating? or a capacitor issue on the mother board. Are there any fuse in the power supply or motherboard that could have blown?
Any one here aware of this. CPU light on, LAN light on, but no boot activity, no harddrive activity, no fan come on and the room lights dip when the computer is turned on.
If it is a motherboard issue, can the motherboard be repaired? Replacing would be another uphill task with Win XP Pro.
Thanks
  • 2 more comments
  • Anonymous Apr 21, 2009
    Thanks **** and Gunnifo.
    Last time it failed to reboot, it tried ****'s approach and disbled video card, memory, DVD drive etc and still it would not reboot. So the area that were left were the power supply and the motherboad.
    This time nothing seem to be working. I can try replacing the motherboard and the power supply. First the power supply and then the motherboard.
    Can you suggest which new motherboard would be a better replacement for Intel D845PEBT2. I do a bit of graphics and video work.
    Thanks
  • dkparsai Apr 22, 2009
    Thanks guninfo. Power Supply was the issue. Replaced it and things are back to normal. PC is up and running.
    Thanks again to both you and ****
    Thanks guninfo. Power supply was the problem. Replaced it and the PC is up and running.
    Thanks again to both you and ****.
  • Dick
    Dick May 11, 2010
    Your computer needs to be thoroughly tested to figure out exactly what the problem is. Have you figured out what caused the thermal event warning? You KNOW something happened there, find the source of that problem and fix it before you start on any other problem.
    Be methodical in your troubleshooting. Write down everything you try and the results. Change one thing at a time.
    The problem you describe could be anything - power supply, video card, memory, motherboard. Coupled with the thermal failure I would guess a fan failed and caused something to overheat and fry itself. Perhaps you got lucky and the system shut down before any damage was done. Only testing will determine that. You have a long road ahead and it may be more cost effective to replace the computer. How much is your time worth?
    Scholar:
  • 117 Answers
Have you tried to boot into safe mode during the PC's post? Quicly tap the F8 key while booting. Choose LAST KNOWN GOOD CONFIGURATION and press enter.
It sounds like a bad day for the motherboard. You actually unplugged and plugged in the motherboard while it was in operation. Hopefully you didnt fry it, but chances are rather high. Go to Newegg.com, or a local PC reapir store in town and buy at least a new, not used, 350w PSU(power supply unit).
Before you do anything else, buy a few cans of commpressed air and clean the inside out. Dust is a PC's worst nightmare.
Try these things and see what happens. But never ever unplug the board power while it is running, or in your case, trying to.
Posted on Jun 10, 2009
  • 59 Answers
If you computer over heated, this could have caused the board or power supply to short. I would first start by trying a new power supply unit (since this is cheapest of the options). If that does not work then try replacing the motherboard and/or processor. Since you not getting any power, my guess is motherboard or power supply unit.
Posted on Apr 20, 2009
Segate portable hard drive 500 gb not able access
is the computer see ing it if not ,unplug run computer then turn off re plug in and computer should see it with its plug and play system
Jul 06, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Clear pasword and boot block recovery problem
At the bottom of your motherboard there should be a 4 pin stand with a jumper on only two of the pins.Move the jumper to the remaining two pins and reboot.
Oct 11, 2009 | Intel Motherboard
Problems trying to format my SEGATE 120GB external harddrive
See Seagate's SeaTools download page. You should be able to download SeaTools for windows, and use it to diagnose any problems
Sep 27, 2009 | Seagate Computers & Internet
Hi, I bought a new computer desktop last month and I have problem with my Hard drive. I bought a big machine for my business. -CPU Intel core I7-920 -Intel DX58S0 motherboard - 4 GB DDR3 1333 Kinston...
My guess is that there is not enough cooling in the case. Those drives make a lot of heat, and if stacked closely, will cook themselves. See if your case has locations for additional fans (especially over the drive bays) and add them. Remember that the power supply pulls air from the case, so make sure the additional fans are blowing into the case.
Sep 18, 2009 | Intel Motherboard
No boot but with power and fan moving
when your bios setting is wrong, you just have to set it to default by unplug it and then plug it again..and done, your bios is set to default
have you try change your data cable?it maybe damage
or could posibly your harddrive is damaged, you can try a simple experiment, try it to another computer, or try the motherboard with another harddrive....if its OK, then you have no problem with your harddrive......and perhaps your motherboard are damaged...
Jun 29, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Computer comes on, goes off, comes on, goes off, comes on, etc...
Troubleshoot by replacing SMPS ,RAM, motherboard and hard disk one by one
Jun 23, 2009 | Computers & Internet
Segate SATA HDD Cannot perform properly
Go to BIOS at machine startup. check the device, make sure hte SATA is set not at IDE.
Apr 09, 2009 | ASUS K8V-X Motherboard
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Mistankenly i connect config jumper on fan connecctor
Try resetting the BIOS to default,and see if it clears the error.
let me know if this works.
Thanks
Dec 12, 2007 | Intel D945GNT Motherboard
Intel Desktop Board D845PEBT2 Motherboard Logo
149 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
