Question about HP Photosmart C3180 All-In-One InkJet Printer
Photosmart C3180 not copying properly
I replaced the black ink cartridge (which I've done a few times before), did the alignment, etc., but when I tried to make a copy (scan) of a document, the page came out blank. I kept trying, and the photosmart sounded and acted like it was working properly, but pages still came out blank. I left it alone for a couple of days, then tried again. The first page had just a little black ink on it, the second more, and so on. I scanned the document about 10 times, but it still is not printing everything: some entire lines of text are "faded" or the upper parts or lower parts of the entire line is faded and not legible. It's worse at the top of the document, a little better toward the bottom. Your help will be appreciated, please.
  • braicmihaela May 05, 2009
    I want to change ink ...the black one
Mke sure there is no sticky tape on your inkjets
Posted on Apr 30, 2009
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
Bought used Photosmart C3180 printer. Need to know how to insertcartridges. Thanks
for this particular printer, there are two slots, one with a green triangle and another with 2 different shapes. The left one is for colour and the right for black ink.
First you want to pull the desired cartridge out by putting a finger on both top and bottom and it should literally slide out (if it doesn't first time lift it up slightly first). Save the cartridge for future refill and the cartridge you want to put in you hold the same way and again from the bottom just literally slide it in. You should be able to click it in once it is all the way - this indicates it is in correctly, the printer should now run a test print
May 24, 2011 | HP Photosmart C3180 All-In-One InkJet...
The following print cartridge is not intended for use in this printer for HP-Photosmart C3180. Cartridge on Right . Not able to use Compatible ink cartridge for this model? any solutions?
The ink cartridges that can be used with this printer are HP92(black), HP93(tricolor), and HP99(photo). You can use other brands that cross over to the HP numbers but they would be the only cartridges you should use for proper operation.
Sep 26, 2009 | HP Photosmart C3180 All-In-One InkJet...
Will HP Photo copy with only one cartridge?
No.
You need to have both cartridges for it to operate properly.
Mark
Mar 27, 2009 | HP Photosmart C3180 All-In-One InkJet...
Ink cartridge
Black HP 92
Color HP 93
Photo HP 99
Jan 11, 2009 | HP Photosmart C3180 All-In-One InkJet...
Cartridge alignment function repeats
you must replace both ink cartridges to get a sucessful alignment.
Jan 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
294 people viewed this question
Seeker5211
Seeker5211
