Sometimes my freezer will warm up and the food will thaw. Then it starts working and the food will refreeze. What can cause this problem? Thanks.
HI,
The most common problem is a bad start relay on the compressor.
In rare cases the compressor may be bad.
If you are mechanically inclined you can replace the relay yourself for less than 50 dollars.
You will need model and serial number off of the unit and order the part by those numbers. i
f the compressor is bad you will need to hire a good service company
thanks,
The refrigerator temperature is always good
But the refrig section always stays cool. Wouldn't this also be affected? And the fan in the freezer continues to work. Do you still think it's the relay? Thanks.
