Question about RCA T19060GY 19 in. Combo
Need to scan channels without remote control
I have lost the remote control for the TV and I need the TV to check and detect all the channels present on the cable without the remote. I tried several remote controls and no one works with this TV.
  • Anonymous Sep 04, 2008
    No remote for this tv. I can't get to the munue so I can program the tv. I have Direct TV service.
Hi I seem to have lost the digital channels on the tv after pressing the "tv" button on the remote. There are 2 remotes 1 for turning the tv on & off the other for changing the channel/volume.
Your remote control need cleaning. Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. [open and clean] [open and clean]
Nov 28, 2016 | Televison & Video
How so u auto scan a Sanyo led without remote control
Many TVs require a remote control to access any function other than Vol+/-,Ch +/-
Apr 23, 2016 | Sanyo 42 in. LCD TV
Need to find a "enter" button on the TV
You won't have much luck attempting a channel scan without the remote.
Nov 11, 2013 | Kitchen Ranges
No remote need tv in av mode
While ur TV is connected to d AV device which must also be on, run a frequency scan and all available channels including ur AV channel will be detected and saved. After d scan, u can manually change channels to ur AV choice.
Jun 06, 2013 | Televison & Video
I lost my Original Toshiba remote control for my TV and I need to do a channel scan that is in the setup menu, but the TV itself doesn't have a setup button to push to access the scan function, How...
You can buy a universal remote, any best buy will carry one, I have even found cheap ones at dollar tree or dollarama. They come with a manual with the codes for the make of your TV just follow the coding instructions until you find the one that will operate your TV.
Good luck
Jan 19, 2018 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Remote was lost. Tried to adjust the station and now I cannot get the TV to go to channel 3 so converter box will not work. Itied a universal remote did not work. Help
I assume, that the TV is skipping chan 3 when using the Channel buttons on the TV.
You can try 2 things.. First see if your converter box will use chn 4. Usually there will be a very small switch on the back of the box marked with a small 3 on one side and 4 on the other. If so, use that till you get a replacement remote.
If that's not an option, you can also, Re-scan the channels on the TV. to find all available chn for memory.. BUT FIRST making sure that the converter box is on and working.
The TV shuold then detect that there is a signal on chn 3 and make it available to the chn buttons on the set.
You will have to use the menu buttons on the set to do this.. Hopefully one of the buttons is the menu call up, then you use vol or chn buttons to navigate it.
Hope this helps
Dec 03, 2010 | Televison & Video
Good day,
I might be missing something here, but if YourTV has the basic controls on the TV itself, such as on/off volume, and channel select, then just turn on tv, and set it to channel 3.
Use your converter box remote to scan for channels, and other options it has as needed.
Jan 23, 2010 | Televison & Video
Only 5 channels
Try purchasing one of the cheap "All in One" universal remote control handsets.
Feb 18, 2009 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
Sep 09, 2006 | RCA T13208 13 in. TV/VCR Combo
RCA T19060GY 19 in. Combo Logo
1,084 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
