The fiorino name have been used by Fiat since 1977. Please be specific on the model year.
Fiat also have 1.4L engine called FIRE. Used by so many models.
there are no timing marks for camshafts you need a fiat tool to lock the cams rear of engine but if you mark the cam sprockets carefully before you dismantle you should be ok if not borrow the fiat tools the crankshaft marks are on the front pulley end about @aprox.10oclock position
post the symptoms. "cant switch off what, exactly"?
the FSM covers the tests, ever heard of the FSM. (buy it at the dealer)
or alldata.com1.9JTD,
i get to decode JTD ,thanks for not posting maker , model
Is this a FIAT"? why must i guess.? uniJet Turbo Diesel,
Some PSA Peugeot Citroen diesel engines are also rebadged JTD units.
Applications:
fiat punto ,1.2 its a valve free engine so it will not bash the valves ,the bottom pulley mark points at teh top ,you will seea corresponding mark and the cam is top left hand side ,you will see another coresponding mark their for the cam on the ally rocker cover
First you need to get the radiator cleaned up and then fill it up with a good quality coolant and not water and for oil leakge you need to get in touch with a mechanic so that he can replace the oil seals, i also have the same problem with the oil leak and i changed the oil seals and its working fine since then.
