Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I need a diagram of the trigger wiring in my bissell proheat 8930
I took apart the upper handle of my bissell proheat 8930 to check a problem with the trigger. there are two wires that plug into the black switch for the trigger and three prongs that these wires can clip on. I need to see a diagram or find out where to plug these in. My manual does not show a diagram of this.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sgsgff
Posted on Sep 30, 2010
I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
Dec 11, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need diagram of fluid tube connection. Husband took apart and doesn't remember where the lines go.
Go to the Bissell website: Bissell ProHeat 2XTM Service Center Guide. You'll get some very useful info there.
Good luck, I just did mine.
Mar 14, 2014 | Bissell 9200P ProHeat 2X Pet Upright Deep...
I took my bissell 9400 series apart to clean the heater and the hoses were clogged. now I'm not sure where they go, i get all solution now and no water. i cant find a diagram of hoses nowhere,
I've taken some pictures of the inside of my Bissell Proheat 2x Plus and posted them here:
http://bbay.dreamhost.com/bissel_proheat_2x_plus/
Best of luck!
Nov 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
PROheat cleaner model #8930 will not despense liquid.
yes if it sprays from the hose its the heater clogged its in the handle if no spray replace belt check on rinse only
Dec 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I NEED FREE DOWNLOADABLE SCHEMATICS WITH TUBING LOCATIONS FOR THE BISSELL 8930 PROHEAT 2X
heatman101
ety24
Nov 19, 2009 | Bissell 8930M Upright Steam Cleaner
I need a picture of the liquid hoses on a 8930-m bissel
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
Mar 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Proheat Carpet cleaner
My Bissell had the same problem. The hand attachment does not use heated water. So I Found a clog of calcium and dirt in the heater portion of the unit. The heater is in the handle behind the red heater light on the front. Remove the upper portion of the handle. Remove the lower two screws in the lower portion and the parts will split apart. Remove the hoses and remove the heater. (mark where the wires go) The bottom of the heater can be removed with a screwdriver. The tubes leading into the heater is where the clog was but there was a lot of debris inside Make sure to clear it all and the hoses as well. I put it together and it works great.
Nov 23, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
723 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
