Question about Southwestern Bell Lands Phones
Static from a wireless (plugs into the wall)intercom
Why am I suddenly getting this extreme amount of static when I press down the talk button? It is obviously getting the signal and the line of communication is open; but you can't hardly hear the other person speaking because of the static. It only does it with one of the units.
  • rabbit2526 Apr 20, 2009
    This problem is not for a cell phone....it's a wireless intercom. One is out in our detached garage and one in the kitchen. It's worked for about 15 years. We took it apart to see if anything was loose in the wiring; but did not spray it with contact cleaner. We're going to try that today. Thanks
  • 40 Answers
There are a few possibilities that could be the cause. The fact that its only one unit malfunctioning most likely means it is some type of fault in the unit it self and not the connection. Have you swapped it with another unit to make sure its the unit itself? If so try these. The first and most simple is the easiest to fix. It may sound odd but dirt and other contaminants can cause a great deal of interference "static" when they get worked into the metal connectors that carry signals. If that is the case, I recommend that you unplug the device and use "electronics" contact cleaner on all the connectors and if possible the metal contacts themselves. If it is not a containment then it could be a loose connector blown speaker/mic or even a solder joint inside the device. If that is the case you may have to have it repaired.
Hope this helps.
Posted on Apr 20, 2009
  • 89 Answers
Your wiring is bad you are going to need to get another phone unless you can putt up with the static of the phone
please rate if i have been of any help to you
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
My Intercom Extention shows busy. I have disconnected my Aneritech M7310 from the wall and reconnected, but I still can not dial out or receive incoming intercom calls. I have tried the #85 feature to try...
if the arrows constantly lit see if the intercom button is stuck down. sometimes junk gets down arround the button and doesn't alow it to release.
Nov 30, 2009 | Lands Phones
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
I can't set up the intercom system on my Avaya Partner ACS R7
To program a page button for other extensions.
At the phone, press Feature 00
press the LIGHTED button you want to program.
press the LEFT intercom button, followed by * (star) and the 2 digit extension number.
Repeat for more buttons.
Feature 00 when done.
Now you can just press the button, and it dials intercom *10 (example)
it will activate the speakerphone and you can talk.
Jul 09, 2009 | Avaya Corded Phone avaparp18d
Sears garage door opener problems
We had the same problem.  open the unit and checkt the connections.  we had a few loose wires and every time there was a vibration whether a low flying plane or a truck nearby the door went up.  My husband found a few of the wires had loosened up.
Jan 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Static
SYSTEM RESET To recover from some fault conditions (refer to the Troubleshooting Section) you may need to perform a system reset. To perform the system reset follow this procedure: 1. Press both the talk button (14) and the mute control (15) button on the headset for 5 seconds. 2. When the talk indicator light (17) on the headset blinks, release both buttons. 3. Press the talk button again. 4. Next reset the base unit by disconnecting the AC power adapter (24) from the AC power adapter jack (7) for 5 seconds, then reconnect. The system reset operation is complete.
Jun 19, 2008 | Plantronics CS50 Wireless Office Headset...
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Remove power cord with no backup battery
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set.) Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
May 17, 2007 | GE 2-9450C Corded Phone
Lands Phones Logo
159 people viewed this question
Top Southwestern Bell Lands Phones Experts
Outback Jack
Outback Jack
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
