Question about Sharp 32C241 TV
Sharp television model 32c241
Won't turn on.
    Genius:
  • 1,139 Answers
This is a power supply problem. It may be as simple as a blown fuse or as complex as a problem with overvoltage and overcurrent events within the circuitry of the Horizontal and Hig Voltage sections of the set. If it is a fuse that's simple to replace, the other well that can get kind of involved. In any event I would suggest that you get the set analyzed by a qualified Television repair person.
Posted on Sep 22, 2007
DEAD T.V.
Posted on Jan 14, 2009
Adjusting Screen size
After looking at the instruction manual, there doesn't appear to be a way to change it.
This model may not support that.
http://r.search.yahoo.com/_ylt=A0LEV7yzpxBVBB4AcxglnIlQ;_ylu=X3oDMTEzMW0yNTZkBHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkA1lIUzAwMV8x/RV=2/RE=1427183667/RO=10/RU=http%3a%2f%2ffiles.sharpusa.com%2fDownloads%2fForHome%2fHomeEntertainment%2fTelevision%2fManuals%2fArchive%2ftel_man_32C241.pdf/RK=0/RS=dmPLmXUVT6evfsRih.cZNSlewzA-
Mar 23, 2015 | Sharp 32C241 TV
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Sharp Model # 32C241 shuts itself off. When I unplug it for a few minutes and try again, it starts up and runs fine. Has happened twice this week. I'm disabled and money is an issue. What causes this and...
You could try and switch outlets and see if that helps. If it continues to do the same thing access the T.V. menu from your remote and check to make sure you don't have a sleep timer set. If there is no sleep timer and switching outlets doesn't help then my guess (from my own experience) would be that it's probably on its last leg and would require a repair. If it does require a repair then you would probably have better luck buying a new T.V.
May 03, 2011 | Sharp 32C241 TV
I need a part number (or the part) for the Sharp TV, model number 32C241. I think the part is JBTN-0132GJKB but I can't correlate the number with a picture to be sure. The part I'm looking for is the...
I am unable to locate of picture of that part either but when Sharp says "power button" the on-off plastic push button is what that means. The cheapest I found it was on the mcm electronics website.
Aug 17, 2010 | Sharp 32C241 TV
Hello, TV turns on and can get to the MENU, but no picture. I hooked up to a smaller tv with the same cables and picture is clear as a bell. Any thoughts on how to get a picture? Thanks
Make sure you select TV as an input, then do a channel scan. If that did not work, then TUNER of your TV most likely a problem.
Nov 17, 2009 | Sharp 32C241 TV
Where i can download a free schematic diagram for 32c241 sharp tv.thank you
a free diagram will be very difficult to track down with that specific model. is it CRT or LCD or Plasma? your best bet would be to find a couple repair diagrams for tv's of similar type (google "tv repair diagram and scroll through the image search results.)
if it is a CRT then it won't be too bad, as they are pretty universal in the way they're built on the inside, so looking at a couple CRT repair guides should yield a good idea of what to expect, what might be moved around, and what stays constant.
your next option (which i am sure you are aware of) will be to call Sharp and request one from them, and it will most likely come with a price.
is there a specific problem with the TV that prompts you to need to disassemble it? perhaps we could better help with a specific problem. if you're taking it apart for fun, skip the diagram and jump into it. inside any electronic will just be circuit boards mounted to parts of the frame and a tv tube in this case, so you really can't harm anything by gently taking it apart. putting it back together is a matter of fitting the square peg into the square hole, so-to-speak, as the boards won't fit properly on any side other than that which they were removed from. cables are the same way.
hope this helps a little.
Jul 09, 2009 | Sharp 32C241 TV
TV Turns off by itself
its the tuner ic nuber 536 faulty on the main board or the capavcitor number c762 faulty.that needs replacement.
Mar 06, 2009 | Sharp 32C241 TV
Will not turn on
the power supply is the problem! so bring it to the expert technician!
Feb 17, 2009 | Sharp 32C241 TV
Sharp 32sf560 TV
Good day
You an adjust the screen brightness on the rear portion of your units flyback. Then the intensity of the color will change.
chris
Feb 02, 2008 | Sharp 32C241 TV
Tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Apr 13, 2007 | Sharp 32C241 TV
Televison & Video Logo
206 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
