Question about Garden
Removing the pawl assembly
How and where do you hold the shaft so that you can remove and replace the starter pawl assembly on the echo weed eater?
  • sunfish78163 Apr 23, 2009
    I found out that you remove the spark plug and put a piece of rope into the spark plug hole and slowly turn the shaft. This will cause the piston to bind onto the rope and not damage the shaft or piston. Once this is locked tight then you are able to use a socket wrench and remove the nut that is welded to the pawl assembley.
    You can then install the new assembley and tighten. Then remove the rope and re install the spark plug. You are ready to go once the gas tank bracket is reinstalled.
#1 Taper
  • 1041 Answers
SOURCE: Don't know how to install new string on Echo SRM 2400
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
pumpkinman
  • 1165 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
moretons
  • 155 Answers
SOURCE: Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Posted on Jul 26, 2009
SOURCE: lost manual for troy bilt weed eater mod#tb514cs 4cycle
I didn't find that exact one either, but recently had to work on my Yard Man 4-Cycle Straight Shaft and used a Troy-Bilt manual for a similar trimmer - worked great.
If you don't find yours at this site, maybe a similar one will work. It looks like the difference is the TB525 receives attachments. If you're trying to fix something right now, here's the manual for that one until you find yours:
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/big_red_tb575ss.html
Posted on Sep 08, 2009
bbreton
  • 437 Answers
SOURCE: echo pb413h blower removing starter pawl assembly
I looked on ECHO website for serial#0200-02999. the part number is 17720206210. you don't need a pneumatic tool to remove it but it is nice to have. I would not use the high setting. But you should be able to use just a socket to take the old one off and put a new one on.
Good Day.
Posted on Oct 16, 2009
Pull cord on weed eater won't engage
If the pull cord does not turn the engine over, the starter pawls are probably not working properly.
Jul 13, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Have a ECHO gas trimmer SRM 2100 wont start. coulld it be the fly wheel
If it doesn't turn over when you pull the rope it could be in the starter assembly or the flywheel where the starter pawls engage it. If it turns over then you need to check for fuel, spark, air and compression.
Jan 20, 2013 | Echo 2-Cycle 28.1 cc Straight Shaft Gas...
How to fix my echo gt200r gas trimmer I was trimming with it and it got hook on a vine. Then when I engaged the throttle it spun for a second and then stopped, tried a couple more times and it did the same...
remove the head from the shaft( tube) and remove the broken drive cable
get and fit new cable and then reattach the head to the shaft ( tube )
the gears in the head are fairly robust but the drive is a cable which twists up and pulls out of the drive squares at either end
Aug 02, 2017 | Echo Garden
Echo pb413h blower removing starter pawl assembly and installing new one.
Good Day.
Oct 16, 2009 | Echo Garden
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Weed Eater PE550 - How do you change the spring that operates the cord pull. Cord not rewinding. Spring broken
Lay the unit on it's side, carborater down. Removed the 3 screws holding hold the gear assembly housing. Hold the clutch assembly inside a cloth with a wrench and remove the nut. Left from the starter cup as a stack and set aside. There is a starter retaining ring on the shaft. Pull this with a long nose plyers. If it spings free, it is easy to loose. Then left out the starter pully. The starter spring is under the pully. Remove it with a sharp pointed tool. A broken one is crusted in rust and will be snapped off inside the coil.
Jul 31, 2009 | Poulan Garden
Replace starter line on my Poulan 446T PRO Weed Eater
Its quite a job to get to the starter, you need to remove the tube and shaft from the motor, then remove the tube housing held with three screws, once removed you will find the clutch, remove the securing nut clutch and washer, now remove the screws holding the clutch housing and remove, the starter pulley is housed in this housing.
Oct 10, 2017 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
520 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
