Ink remains wet and if touched smudges.
After printing the copy's ink stay wet and does not dry, if touched ink smudges. savin 2527model
  • 59 Answers
Sounds like the fuser is bad...try installing a new fuser.
Posted on Apr 20, 2009
Ive just bought this printer from currys & im trying to print a picture from my memory sd card & the picture is coming out all smudged? could it be because im not using photographic paper?
You should be able to select the paper type you use before starting the print. The printer should optimise the print to match the paper you have specified. If the paper is not for photos, it shouldn't matter too much unless the ink is taking too long to dry. It is more likely that your print heads are skimming the paper or something is brushing the image while the ink is still wet.
Apr 13, 2016 | Office Equipment & Supplies
Element that dries the ink on photos isn't working after replacing ink cartridges.
heating element in a photosmart printer?
have you made sure you're printing to the right sort of paper in the printer settings. it's obviously dispensing too much ink for the paper you're using.
Mar 15, 2015 | HP Hewlett Packard - Photosmart 7520...
Copies of documents are not clear
Spots on copying: Chk is there any marks on flat bed glass?,clean flat bed glass with wet cotton cloth, allow it for dry.
Spots on printing: There is no particular reason for this issue. clean paper path with wet cotton cloth & allow for dry..
Mar 18, 2013 | HP Deskjet 2050 All-in-One Printer
After printing the ink stays wet and so smudges. I have fitted a new cartridge
hello, try a different paper type, from another manufacturer. have had same problems with purchasing bad paper. also make sure, paper is going into machine properly. for your machine glossy/ or clay coat up
Oct 22, 2010 | HP Photosmart 325 InkJet Printer
When printing a document on printer it prints a line and then a solid black line beneath that.
Sounds like a bad ink cartridge. The ink is probably clogged up in the print head where the ink comes out of the cartridge. You should either bring it back to where you purchased it for a replacement, or you can try priming the ink.
To prime the ink:
1. Get a wet paper towel
2. Get a dry paper towel
3. Take the bad ink out of your printer
4. Move the ink back and forth from the wet towel to the dry towel touching the print head (part on cartridge where the ink comes out) to the towel.
5. You should begin to see the ink come out in a higher consistency
This will help unclog any ink stuck in the pores of the print head. If that doesn't work, you may need to get a replacement from where you purchased it.
Hope this helps :)
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Smudgy Photo orints
Make sure you are printing on the correct side of the paper. Most photo paper is single-sided. If you print on the wrong side, the ink sits on the surface, pulls up into very small drops, and remains wet for quite a while. If you print on the correct side, the image should be dry to the touch within 15-30 seconds.
Jul 29, 2008 | Canon PIXMA MX300 All-in-One Printer
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Ink smudges
Pease check:
thet consumables is originals,
drum cartridge is not damaged
transfer belt is clean and not damaged.
you may have problem there, but if not you can try update firmware, maybe its a firmware problem.
first check consumables and if possible try changing them
Oct 23, 2007 | Konica Minolta magicolor 2430 DL Laser...
jasbo
jasbo
