Question about Maytag Neptune MDE5500AY Electric Dryer
NOt drying clothes like it should
Maytag- Neptune
Model # MDE5500AYW
No lint obstruction,
Dryer feel very hot on outside.
Feels hot on inside but it just doesnt seem to be drying the clothes.
It was taking about 45 minutes to dry a load, now it is taking up to 2-3 hours.
    Problem Solver:
  • 16 Answers
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Posted on Apr 20, 2009
My Maytag Dryer, Model No. ldg8404aae, is taking too long to dry the clothes. After Turning the dryer on the Vent Pipe gets Hot and then after a little while it feels cool. The vent feels like it is...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 13, 2011 | Maytag Dryers
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
My dryer takes forever to dary and the lint and the clothes feel damp. I can only dry 1/2 a load at a time. Whart's wrong?
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also, make sure the duct is not kinked. Also, your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Dec 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Dryer gets hot but takes along time to dry
Make sure the lint filter is clean. If it is make sure the hoses leading from the dryer to the outside are not clogged. It sounds like it is not getting prober airflow through the tub.
Jun 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Clothes aren't drying
Check the vent ducting for obstructions, like lint deposits, insect or birds nests and kinks in any of the flexible duct.
May 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The Neptune has been taking forever to dry
when a dryer takes along time to dry you have a venting problem,, icant telll u if lint is clogged up inside the unit,, or lint is inside you venting, or if lint is cloggged up inside you vent piping through the hose,,, this is common if you have a long vent distance before it exits the house, or possibly the vent is kinked and your dryer is pushed back to far.....
to check undo the venting to back of the dryer and run a load of clothes with no venting hooked up if this drys faster than u know that where your blockage is occuring......
A lil trick also check outside when running you should feel air blowing
also use a leaf blower from inside put in hole of ducting andd blow that line out clean it out hope this helps feel free to leeave me a testimonal leetting me know how things went ...k take care good day
Feb 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Maytag dryer model # SDE3606AWY HEATS UP TUMBLE clothes but does
There is most likely a lint obstruction somewhere in the exhaust. Start by checking the outside vent as often there is an animal screen on it that over time gets caked with stray lint. If that's clear then work backward and check the hose, etc until you either find something or get to the dryer itself. It's possible that in the internal exhaust tubes there's an obstruction as well so if you don't find anything in the external tube you will need to disassemble and have a look inside those internal exuast tubes/ports. If it's inside then do it soon as there's clearly a risk of fire if there's a wad of lint somewhere inside where it shouldn't be.
The mother of a friend at work had this issue - her clothes took HOURS to dry. Her animal screen had several inches thick layer of lint. Once that was removed the dryer dried like new.
Mar 29, 2009 | Maytag SDE3606A Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
318 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
