Envelopes print in color and I want black only
I have an HP Officejet 6480. I want my envelopes to print in black but keep getting red, purple, yellow and brown. What am I doing wrong??
  • 228 Answers
First you need to change the settings in the software you are trying to print the envelope. Open the program (for example MS Word), go to the option from which you print envelopes and labels. Set the font color to black, not "automatic", and in Word, click "default", which sets the color as black rather than allowing the printer or its software to select the wrong color. Then try to print on the envelope and let us know if you are able to print the envelope in black only.
Posted on Apr 21, 2009
  • Roopesh S
    Roopesh S Apr 21, 2009
My Officejet R80 prints only in red and black; Any suggestions
Color cartridge dried up..Perform clean cartridges through printer properties.. check,,no result, replace color cartridge..
Sep 01, 2012 | HP OfficeJet r40 InkJet Printer
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
I bought and replaced the black and yellow printhead today. It printed some colored pages. Then when I began to print this evening a colored page. It stopped in the middle of printing and the printer...
please take your print head and get it tested or get it replaced, or you could take your printer to a local HP service centre and get it checked, rather than trying to fix it yourself you mite damage the sensors for the print head.
Sep 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
How do you print envelops - the names are never centered and theirs a ig space between name and address on envelops hp office jet pro 6480 all in one
Since there are few step you have to complete before you can pirnt envelop
and theis site will not let me listed all of the step and pic to show you how it is setup.
the following link is the HP 6480 printer define how the evelop printing is done.
start on page 21.
http://h10032.www1.hp.com/ctg/Manual/c01325559.pdf
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How do I change the black printhead of an HP Officejet 7130xi?
Yes, you can only replace the black printer head.
Is it saying that you have a bad print head?
If not, try to get a paper towel and fold it to be a little thick and get it humid (not too wet) and let the printer head soaking on top of the paper towel for an hour or so.
If the problem is because the printer head is dry, that usually resolvs the problem.
I had the same problem a while ago and I even did that with the color printer heads.
Good Luck,
Oct 03, 2008 | HP Officejet 7130 All-In-One InkJet...
148 people viewed this question
k24674
