Question about Acer Power FH PC Desktop
Wiped clean cannot reload windows
Trying to reload windows back onto acer power fh desktop. wiped clean with windows 98se boot disk. reformatted. ran 98se operating system disk. froze up.
  • Steve French Jan 04, 2012
    First off I just want to say that ACER was a taiwan based computer company that developed in the early to late 2000's,the windows program you're putting into it was made when IBM Thinkpads were cool!Bottom line,wrong windows,how about trying a more modern day windows like XP at least,if your computer is to old for XP then get millenium,but my guess says that you have a newer version acer which ONLY contains either a windows vista,windows XP,or windows 7 ONLY!WITH NO BACKWARDS COMPATIBILITY WHATSOEVER!!!-Now if this is the case then rewipe your system and get the right windows for it!Hope this helps! -CB
    Problem Solver:
  • 12 Answers
Are you using a floppy or a disc? Your CD rom or disk may be faulty. If you have another copy and/or another cd rom drive try that. Also reseat the memory sticks. Lastly it all of this fails your hard drive may be the culprit...
Posted on Apr 20, 2009
Re format acer deshtop
Use your Microsoft Windows CD diks that came with your computer.
Boot off of the disk by setting the CD Drive as first boot device. Set this in the BIOS.
Take care!
damnor01
Sep 22, 2012 | AcerPower FH (APFH-EP9150C) PC Desktop
I purchased on old acer aspire. it had a windows 98 upgrade. There were windows 95 and windows 98 files and 98se files, but half the programs were missing or the uninstall file was gone or corrupt. I did a...
You probably need to tell the BIOS to boot from the CD.
I'm not certain about your model, but you can try pressing delete button as it's doing initial start up, to enter bios. It may even display on screen what to press for bios. Then look for boot sequence options, and have the cd be the the first boot device.
If this works, you may see a message saying "press any button to boot from cd" if you don't do this , it will still fail to boot on cd.
If it works out for you, you should change this option back after completeing the install.
Mar 12, 2011 | Computers & Internet
My acer laptop turns on, then tells me to contact the systems administrator. If I try to continue it shuts down. at one time I recall reading that the files have been currupied. is there anything I can...
It sounds like the Windows boot files have become corrupted. That could happen for several reasons, but if you're willing to just reformat/reload the operating system, we're only concerned with one of those reasons.
There are some viruses that can corrupt boot files. If that's what happened, then reformatting/reloading the OS will take care of it.
On the other hand, it could be that your hard drive may be failing. When you reformat/reload, the Windows system will tell you if it finds errors on the drive.
The following is from the Acer manual for your machine as to how to access the BIOS and enable a hard disk recovery:
To activate the BIOS utility, press during the POST; while the notebook PC
logo is being displayed.
Boot sequence
To set the boot sequence in the BIOS utility, activate the BIOS utility, then select
Boot from the categories listed at the top of the screen. [You should set the CD/DVD drive to be the first boot device, in case you need to reload from a DVD]
Enable disk-to-disk recovery
To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the and keys to set this
value to Enabled.
[End of manual quote]
If you're not able to restore from the hidden partition on the hard drive, which may happen if the drive is damaged, then you'll have to try to restore using a Windows DVD.
Hope that's helpful.
Jan 12, 2011 | Acer Aspire 3680 Laptop
My laptop E625-201G16Mi has windows Vista home basic, which is pre-installed so no disc. I need to wipe it and re-boot it, how can I do this?
One way to wipe out your computer is by Getting a Vista Disk or Operating system of your choice. It has to be a full installation disk. Try WIndows 7!!! I use it its great..When you install a new OS(operating System) it gives you the option to reformat your disk drive which in turn wipe out all your data and give your computer a fresh clean install..first things first..get a Valid Copy of Windows of your choice. I recommend WIndows 7 Professional.
Jun 17, 2010 | E-Machines eMachines Desktop PC
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
How to reformat acer aspire one
Put a Windows XP disk (has to be the full version not an upgrade) into the CD drive and the computer will ask to "press any key to boot from CD". Press a key. Follow the prompts, It is important to delete the partition when asked. Then recreate it. Format the drive with NTFS file system. The setup will go on to reinstall windows automatically.
Now, the only challenge is to reload any software drivers for components Windows does not find automatically. This is a little tricky. Do google search of Acer drivers or go to www.drivers.com.
Also, remember all your software programs need to be re-installed. For example, your Microsoft Office (word, excel, etc). Any games, any virus protection, Quickbooks, etc. The printer software also needs to be re-installed. Hopefully you still have the original disk or if its a Hewlett Packard go to their website.
Aug 15, 2009 | Acer Aspire One PC Notebook
Tried to reboot to factory settings
You have to make sure when going through the setup (if given the option) to install a clean copy and not install windows to another directory. If you have access to a floppy disk drive an easier way would to be to create a dos boot disk and reformat your c:drive. Make sure you do not have any data on this laptop you want to save. If that does not work you can try to get a DOS program called FDISK. It will wipe out the hard drive partitions so that you can reload your laptop from scratch. Let us know how it goes.
Apr 27, 2009 | IBM ThinkPad T23 2647 Notebook
Acer Power FH will not boot Windows XP Pro
Well your explanation was clear but your should've not ruled out the hardware issue. if both computer suffered the same problem at the same time the problem could be within the Desktop itself. I have experienced the same problem with my HP when I move to my new house after 5 years. What happend is that during transportation the vibration lossened up the parts inside your computer. So what I did was I reseated all the parts inside the desktop and reinstalled Windows XP. Till now I have never had any problems yet.
Mar 26, 2009 | Acer Power FH PC Desktop
I want to crash my computer and reload os and software
you dont need to crash your windows all you need to do is to reformat your hard disk and reload the operating system .
Dec 08, 2008 | Computers & Internet
Acer Power FH  PC Desktop Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
