Question about Sony Bravia KDL-32V4000 32 in. LCD TV
Sound but no picture on av3 sony bravia kdl 32v4000
I have the above tv - sky+ and dvd work fine on av1&2 however when i plug my media player using the rca adaptors on side of tv (red,yellow and white leads) into the av3 slot, i get sound but no picture. Any advice would be greatly appreciated
SOURCE: audio via hdmi
I had the same problem with the same configuration. In addition to the HDMI which is (DVD and Audio OUT only by the way) you need to connect the TV to the DVD through a high quality SCART cable as well. Remember to connect the SCART cable only while both the TV and DVD are switched off. To get the TV sound out of the DVD surround sound you need to click the FUNCTION key on the DZ230 remote a couple of times till you get the word TV on its screen, this is when you should hear the TV sound coming out of your surround sound as expected. Good luck.
Posted on Aug 25, 2007
SOURCE: 40" Sony BRAVIA KDL-40S2010 LCD HD TV
what kind of cables are you using? Make sure you get the HDMI cables. Also, the S and V Sony series only have a refresh rate of 60Hz, which means that when you get fast action scenes or when people are moving, you will see a very noticeable blur. There really is nothing you can do about this. I had a V series and immediately returned for a W series, which has a refresh rate of 120 Hz. Sometimes, you can still see the pixelation, especially if the TV can't handle the response time, but it is definitely less noticeable than the other series.
Posted on Aug 04, 2008
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
welcomejee
  • 10594 Answers
SOURCE: I have a Sony KDL-32V4000 TV. I have a Sony
Press Info/ Display button on TV remote, on-screen display will disappear.
Posted on Sep 21, 2009
Testimonial: "Many thanks for rapid response - It Works! Question is why Sony don't put this in the Manual!"
  • 148 Answers
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Posted on Feb 03, 2010
Hi - we lost the screws to fix our sony bravia kdl-32v4000 to the table top stand in a move - can you tell me where I can get the 3 screws needed - thanks
I am guessing the screw size is M6/16mm , based on Sony official page for your TV:
http://www.sony.co.uk/product/tv-80-32-lcd/kdl-32v4000/technical-specifications#tab
Lowes or Home Depot or Ace Hardware (I prefer the latter for more knowledgeable employees). If no hardware stores nearby, try Sears or Best Buy (you may need to ask more than one person, don't give up too easily). If visiting a hardware store, you may have to look in the 'roofing' screw bins or nearby to find the right size.
You might also look for TV mounting kits that have that size screw, but you'd probably pay much more than finding the screws alone at a hardware store.
Dec 02, 2013 | Sony Bravia KDL-32V4000 32 in. LCD TV
I have an sony 32"lcd .the picture turnd into
Sometimes this is caused by a bad connection between the lcd and the lcd driver board. Unplug this cable and plug it again firmly.
Hope this helps!
Apr 07, 2011 | Sony Bravia KDL-32V4000 32 in. LCD TV
Hi, i have a DAV-DZ330/DZ730 and i cant get sound from the tv/sky. TV is a bravia KDL 40NX503. Its HDMI connected and ive been through the sync process and made sure the hdmi settings are ON on the amp. No...
i had the same problem with my dz330. simply attach you sky box via scart to the back of your sony box and hey presto you should have sound when selecting tv mode from the sony remote
Aug 14, 2010 | Sony DAV-DZ100 System
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
Can't play audio CDs without having the TV on
Your description is not entirely clear, so I have to guess a little here, but I think what is happening is as follows:
1) You are using your DVD player as the source for the CD.
2) Your DVD is connected directly to the TV and the TV then connected to your receiver.
If the above are correct, then the problem is that the TV only has what is called an ACTIVE passthru for Audio signals. This means that the signal is process by the TV and tehn sent to the audio output jacks. With the TV off, the buffer ICs are not functioning, thus no output. Some older sets have what is called PASSIVE passthru.
I don't know your specific DVD model specs, so check to see if you have 2 audio outputs from the DVD (many do) and connect the other audio out directly to the receiver. That will resolve your problem.
Dan
Mar 20, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
Manual
From your profile I worked out you're in the UK (product numbers differ the world over!).
For future reference: go to www.sony.co.uk, and click the support tab at the top of the page - and again click support in the popup. Use browse by category to find your TV (LCD - Bravia). Manuals are here:
http://support.sony-europe.com/tv/lcd/lcd.aspx?site=&m=KDL-32V4000&site=odw_en_GB&odw_model=KDL-32V4000
Chrs
Arnie
Dec 03, 2008 | Sony Part 996804671 Service Manual for...
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-32V4000 32 in. LCD TV Logo
343 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
