Question about Electrolux Dishwashers
Zanussi DE4554 has died, what do we do?
Our de 4554 has died we have tried replacing the fuse without success, none of the buttons work even the on/off button no lights are showing, what do you advise to be our next step?
  • 49 Answers
SOURCE: Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Posted on Feb 21, 2008
SOURCE: Kenmore Ultrawash Quiet Guard 4 dishwasher - clean light blinking
I have the same problem. I called the repair guy and he told me how to do a diagnostic check on it to clear the problem out and let it run a cycle to see if it fixes itself. That cleared my problem with the light but unfortunately didn't fix my problem. Press the heated dry button, then press the normal wash button. Press the heated dry button again and press the normal wash button again. Then let it do its thing. If all the lights go out and it does not run a complete cycle, then press normal wash and start to see if it will run the cycle. To speed up the test cycle, he said you can press Start several times slowly to get it to go to the next cycle one at a time. You will see the red lights change from sensing to washing to drying and so on until it goes to clean. Then try to wash some dishes and see if it works. If that didn't solve the problem, he said it could be that there is food or other items stuck in the bottom and needs to be cleaned out. Just remove the spray arm on the back and top of the dishwasher by the 2 screws and take it out of the dishwasher. Then remove the screws at the bottom and take the screen out to get to the tray at the bottom to see if there is food stuck in there. Pay attention to how you took it apart though, so you can put it back properly. Also check the spray arm and run water through it to remove anything that might be stuck in it. If that doesn't solve it, he said it could be the heater or your motor or possibly wires burned out. I am looking at trying to remove my motor now to see if I can replace it and check that before I pay any money unnecessarily. My repair guy is so busy that he tries to help me over the phone before he comes out. Great Guy. He said that if it is the motor, the charge to replace it is not worth fixing, but if the repair is only 100 to 200, that is definitely cheaper than the cost a the same kind of dishwasher I am planning on purchasing to replace it. They say that because the do not want to work on it. A lot of times they do charge more than it's worth though, so you have to get an estimate concerning your worst possible problem before hand so you can make up your own mind. Hope this helped you. Now I will see if anyone can help me figure out how to remove the motor from my Kenmore Quietguard 4 Dishwasher. Have a great day.
Posted on Sep 28, 2009
  • 296 Answers
SOURCE: My Kenmore Elite 15919001 just stop working from
yes, it sounds like a fuse, or a circuit breaker tripped, or, if it is a plug-in connection, it may have come unplugged(outlet usually under sink. Might also have a loose connection in dishwasher connection box ..CAREFUL HERE;VOLTAGE MAY BE PRESENT!!!
...IT MAYBE THE DOOR IS NOT FULLY PUSHED IN TO ENGAGE SAFETY SWITCH
Posted on Feb 21, 2010
SOURCE: zanussi de 6850
I've just had similar - seems to be a problem in the controller module - they're reasonably inexpensive online.
Undo the top-part of the door, about 5 screws across the top and side - the top section pops out, and the control module is now on the inside - if you free off the connectors (not too simple, but doable) you'll probably find some scorch marks on the PCB ... hopefully the wiring isn't damaged, and you can just replace the PCB ...
If you also have wiring damage, well, trace back and replace as required
(probably too late for the OP, but worth recording in any case)
Posted on Aug 28, 2010
SOURCE: Zanussi Aquapulse DE6854 dishwahser programe lights not working
hi
got same probleme with my aquapulse 4744 slimline
Posted on Sep 25, 2010
Laptop battery died; even after replacing, ever since, audio is not working.
Hi ,
It can't be a driver issue since you can get audio with your headset . So , we are left with dead speakers who need to be replaced or completed by an external set .
Regards .
Mar 03, 2013 | HP Pavilion dv7-6c90us 17.3" Entertainment...
I have had the machine for two years and it just died. None of the dials or toggle switches work, the digital clock display is dead, the coffee maker will not receive power. I have tried different...
The thermal fuse is probably open, it is usually welded to the heating element and tied into the on/off switch, and usually involves the replacement of the bottom section. The thermal fuse prevents the coffee machine from over heating.
May 04, 2011 | Cuisinart DCC-1200 Coffee Maker
My zanussi zwx1605w was washing then just stopped working.
zanussi zwx1605w. i have lost my manuel and cant washing machine to start?
Mar 26, 2010 | Zanussi ZWF1650W Front Load Washer
The machine suddenly died. Is there a fuse or ...? The LED panel was printing info that seemed unrelated to printer status and within a few seconds of that, the machine died. When I pushed the power...
I have a dead MP780 also. I opened up the left side panel, and it looks like there is a fuse on the circuit board. I will test it tomorrow. The fuse cannot be replaced, however, without removing the soldered component from the board.
Feb 16, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Konica Minolta C353 - Error Message C-4554
The C-4554 error identify a Laser Malfunction (K).
You could check flat cable that connect laset to logic unit.
Chech all laser K cables/connections.
If persist you have to change Lasers group.
Bye.
Oct 08, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Ionic breeze quandra died
No fuses that I'm aware of.
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Feb 25, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Washer stopped working
I think your mother board has gone hence none of the other lights are coming on.
If you get the help of a competent Washing Machine engineer they will solve your problem, without having to replace the whole machine.
Regards,
David
Jan 17, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Dishwashers Logo
59 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
