Question about Insignia IS-DVD1001 DVD Recorder/VCR
Sound cuts out
While playing a dvd, the sound will stop for a few seconds and then start up again. I made sure all speakers were hooked up right and working. No problem when using the am/fm. Haven't tried vcr yet. A home-recorded dvd did not have a problem.
  • lancemac Sep 24, 2007
    Have purchased a lens/disk cleaner, but haven't used it yet. Will report after trial.
  • lancemac Oct 12, 2007
    Finally tried the lens cleaner disk.   Made no difference in problem.  With a self-recorded dvd, there was no problem -- only purchased disks.  I think the problem is in disk compatibility.
  • 1,139 Answers
This sounds like a lens pickup problem try using a lens cleaning disk. The recording beam is a higher intensity beam and it may funcion properly.
Posted on Sep 21, 2007
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Receiver cuts out when playing a cd
Could be overheating, make sure nothing is blocking the vents at the top
Could be 4 ohm speaker when you need an 8 ohm-check speakers
Could undersized speaker wire. Go by some lamp cord and splice the ends and use it, do it anyway whether its the cause of the cutting out or not-it'll sound better
By a can of co-contact cleaner, unplug the receiver and spray the heck out of the circuits
Mar 16, 2009 | Audio Players & Recorders
DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Jan 21, 2009 | Televison & Video
Technics amplifier sound cuts after a few seconds operation
hi there if the sound cuts out after a few seconds and then if you turn it back on again if it does the same you might have a few problems ,,
make sure you are not overloading with to many speakers
make sure all positives are to positive and negatives are to negatives
make sure the unit is not over heating or getting to hot make sure it has room to circulate the hot air
and also check the wiring for any breaks or rips that could be touching each other to make it shutdown
when it cuts out its going into safe mode to prevent further damage one of those will defintly be your problem good luck with it hope this helps
Jul 01, 2008 | Audio Players & Recorders
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Sound problem
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Jan 13, 2008 | Denon AVR-1708 Receiver
Mintek MDP-1815 dose not play disc
Please supply me with all the types of equipment that you have connected together and the configuration....accordianman
Jan 13, 2008 | Mintek MDP-1815 Portable DVD Player
Sound cutting out after 40 to 60 minutes of playing a DVD
Have you tryed the cleaning of the lens first?? I would for sure do that. If that dosent work i would connect the unit to another amp and see if it still cuts out too. If it does it could have a problem with the tracking or focus gain/offwet alighnment. These are not consumer alighnments, as you need a scope and the know how to hook up the player to the scope and monitor the rf waveform along with test disc. Other then cleaning the unit theres not alot we as consumers can do. Good luck
Jun 24, 2006 | Pioneer DV-373 DVD Player
Insignia IS-DVD1001 DVD Recorder/VCR Logo
41 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
