How much it cost for scanner top glass - Office Equipment & Supplies
  • 89 Answers
Here id the link to your answer http://www.pixmania.co.uk/uk/uk/r/scanner
please rate how helpfull i was to you as a costomer
Posted on Apr 20, 2009
How do I fix scanner glass on HP6520 all in one
Hardware stores can cut glass to custom sizes. But with a new scanner costing$100, you might just buy a new one.
Feb 02, 2015 | HP Photosmart 6520 e-All-in-One -...
Tip
Cleaning your inside scanner glass
Actually it's a very simple procedure!
Read this entire comment first...then start your procedures!
Disconnect the power cord, disconnect the USB cable, remove the top cover cable from the base by unscrewing the two plastic knobs, lift the top cover straight up. Place the top cover in a safe place.
On a clean, flat surface, turn the base upside down. On both ends you will find a total of four (4) black phillips head screws. Carefully unscrew these four screws and place aside. Carefully lift up the base and the top glass will separate from the base. Set the base aside. You have now exposed the inside glass for cleaning! It's that simple!!! Clean the glass by using a streak-free glass cleaner. Don't spray the glass, rather, lightly spray a clean soft lint free glass cleaning cloth, then wipe the glass. Don't press hard! Use good common sense1 There, you've now cleaned the interior glass. Reverse the procedure and you are finished. Wasn't that simple??
on Feb 15, 2009 | HP Scanjet G4050 Flatbed Scanner
Tip
ALLIN ONE 7410 SCANNER PROBLEM
Flat bed glass top scanner works perfectly fine.
ADF Feeding scanner puts red lines on document shown on preview computer screen and will print same if I save or print the document.
HP troubleshooting tips only covers the flat screen scanner gass top.
Called HP and they suggested I either buy a replacement printer for $250.00 or it would cost $400+ to repair this one.
I removed the ADF (three small screws) and cleaned the small section of glass underneath and reinstalled the ADF component.
WORKS FINE NOW !!!
HP REPAIR PEOPLE ARE A RIP OFF ! DO IT YOURSELF AND LEARN MORE ABOUT YOUR MACHINE BEFORE WASTING ANY MONEY !!!!!
on Mar 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
How to clean the underside of the glass in a HP scanjet 2400
Hi ,
You probably already found this :
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/performMaintDisplay/?sp4ts.oid=297429&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01275864-2%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
According to it , you should normaly contact a HP technician to have the job done . Nevertheless , I succeeded to clean the underside of the glass inside a HP Scanjet 5470C wich seems similar to your model 2400 . If you take of the lid of the unit , you should find two screws in the opening of the hinges . Unscrew them and lift up the the whole top of the unit . You might encounter somme kind of resistance during the operation but I finally succeeded to get the it free that way .
Best regards .
Sep 04, 2014 | HP ScanJet 2400 Flatbed Scanner
The scanner glass inside is cloudy
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
Mar 12, 2014 | Epson Perfection 1650 Photo Flatbed...
How do I replace light in HP Scanjet 5470c
  • 1Unplug it from the outlet.
  • 2 Unscrew the two screws on the side of the scanner that does not house the scanner and copier controls. Remove the plastic covering from the side of the scanner.
  • 3 Open the top of it0 and push on the glass. It will pop up. Remove the glass from the scanner.
  • 4 Remove the old bulb from its lamp by unscrewing it. Screw the new bulb in place. Replace the glass into the top of the scanner.
  • 5 Place the plastic siding back on the scanner and reattach the screws.
Jul 28, 2011 | Computers & Internet
When try to scan, lamp warms up then message received is scanner could not scan. 22 is NOT blinking. The scanning mechanism begins move across the page but only moves about half inch.
The scanner may have one of two problems:
1. Scanner lamp has failed or does not come up to full color temp
2. Scanner attempts to initialize, which means it must move a bit to what is the "home" position where the scanner actually reads a very small coded imprint on the underside of the glass. If this area is too dusty or dirty, that will cause this problem, but also if the scanner motor and worm drive are binding for any reason, such as the scan rails internally being too dry this will also happen.
Locate a service manual and remove the copy glass by removing the lock guide on one side, the glass should lift partially, allowing some gentle cleaning with soft cloth and glass cleaner. Do not attempt to force the scanner to move inside, as it is worm gear driven and such an attempt will strip the nylon gears or worse.
Follow the manual instructions if you need to fully remove the top
cover, glass and platen assembly for cleaning. It is very simple once you are in the interior...but gentleness and care are necessary.
Sadly, parts are difficult to find for all scanners now, and it is often far more economical to replace with a new, low cost and higher performing, higher rez unit for $ 120 or less. Often a lot less.
Good Luck!
Aug 03, 2010 | HP ScanJet 4500C Flatbed Scanner
Canon scanner lide90glass is broken where can i buy a replacement
I suggest you to replace complete scanner instead of purchasing a glass, bcoz this will cost you more, and more over less possiblities that it will work.
Aug 23, 2009 | Canon CanoScan LiDE 90 Flatbed Scanner
Ever Smart Jazz Scanner
you cannot.... mmmmmwhhhhhaaaahahahahahahhahahaha
Jun 09, 2008 | CreoScitex EverSmart Jazz Flatbed Scanner
How do I access the underside of the Flatbed scanner to clean it?
remove the lid by lifting up. There are two philips head screws exposed. Remove screws and lift top of scanner off. Pay particular attention to thumb wheel position when lifting. Go to computer repair center and buy double sided tape. replace tape and reverse process
Nov 08, 2007 | Umax Astra 1200S Flatbed Scanner
44 people viewed this question
k24674
jasbo
jasbo
