Question about Akai LCT2715 27 in. LCD Television
TV Repair Set just seems to make a popping noise and won't show picture.
  • 3 more comments
  • dnpchallenge Feb 06, 2008
  • Anonymous Feb 12, 2008
    No picture, no sound; popping noise in the speakers that appears to have a set frequency of about 1 cycle per second, going from left to right and back, continuous. No physical evidence of failed component - no heat damage.
  • spyderga Mar 05, 2008
    Having same problem. Set just seems to make a popping noise and won't show picture, light flashes amber.
  • dlphillips Dec 12, 2008
    The screen just turned black and no sound but the popping and the flashing light...help..
  • johno528 Nov 27, 2009
    I bought an Akia 30+ inch Model# LCT2701TD a few years ago and no problems. Last night, it would not turn on. The little light below the screen that changes color when you turn it on is now blinking constantly (never has done this)...is there a quick fix or do I need to take to a repair shop? Thx
Dsf
Posted on Oct 23, 2008
  • 30 Answers
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Posted on Jul 04, 2008
Several bad capacitors in the powersupply
Posted on Mar 27, 2008
Tv stop playing after thirty minutes and the picture get fussy and its make a loud popping noise. please help.
About the only simple thing you can try is disconnect set and a box if used from power for several minutes and then power all back up to see if when the units reboot the problem is there or not.
The usual repair cost on a 19 inch set will exceed the replacement cost of that set in most cases.
Dec 10, 2012 | Insignia Ns-19e450a11 19" 720p Hd Led Lcd...
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
JVC HD56G647 TV was working fine. Made a popping noise and now we have no picture or sound. Both lights on the front are flashing in unison. Help!
The popping noise is not a good sign. You definitely have a shorted horizontal IC and probably a bad flyback transformer. You will find several bad capacitors that contributed to this problem. The cost of repair will be more than your depreciated TV is worth. Sorry..look for a new one. Thanks for asking and show a few hands of support!
Jan 24, 2011 | JVC Televison & Video
My tv shows no picture,and a popping noise
I had one of these. It was a bad flyback transformer and bad retrace cap was cooked! Chances are real good you have the same problem. You will definitly need to see a TV tech! This model is very complicated to repair. Thanks for asking and show a few hands of support!
Sep 26, 2010 | RCA HD52W58 52" TV
RCA HD50LPW164 turned on TV made a pop
the loud pop you heard was probably a capacitor blowing its top. The grinding noise is likely high voltage arching that was occuring due to rising voltage since capacitor isn't there to smooth it out.
Nov 02, 2009 | RCA HD50LPW164 50" Rear Projection HDTV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
RCA Guideplus Gold Television
I would guess the popping/cracking goes away when the picture is present. Sounds like a high voltage arc either withing the tube or due to a cracked component in the high voltage circuit. If it's the tube, then the question is: how old is the set and is it worth it to sink $$$ into it as opposed to putting the same into another unit. If it is a defective component, that's much easier/cheaper to repair. Again, age of the set, etc. I hope this helps; definitly a repair for a pro.
Oct 30, 2006 | RCA F32649 32" TV
Akai LCT2715 27 in. LCD Television Logo
175 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
