Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Whirlpool Partner 1, DU1055xtsq2
At about 20 months dishwasher made humming noise and cleaning of dishes became less than desirable. Cleaned pump and spray arms. Noise progressively getting louder. It is to the point where if one is in the kitchen they cannot hear someone addressing them from the living room. Any suggestions on what the problem could be and how to get it apart to fix?
Can I get to the cutting apparatus? I have looked for diagrams or prints for this dishwasher without success.
I appreciate any help one can give me.
Thank you.
reg501
  • 413 Answers
SOURCE: Dirty dishwasher problems
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
If I can assist you further, please let me know
reg501
The FixYa Team
Posted on Jun 22, 2008
  • 117 Answers
SOURCE: whirlpool quiet partner 1 # DU1055XTSQ2
Read this article, it should address your problem.
http://fixitnow.com/wp/2006/03/20/whirlpool-built-dishwasher-includes-kitchenaid-and-some-kenmores-wont-start-clean-led-blinks-seven-times/
http://tclaundryrepair.com/
Posted on Feb 25, 2009
  • 677 Answers
SOURCE: Whirlpool Gold Dishwasher "Quiet Partner' Fills But Won't Wash
www.dishwasherfilter.com will fix your problem. its your water and not the dishwasher.
Posted on Jul 17, 2009
  • 423 Answers
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
wiringlunati
  • 576 Answers
SOURCE: whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Posted on Nov 25, 2009
Whirlpool dishwasher doesn't make the regular sound
The problem could be a clogged water line or intake valve. Check the lines and make certain they are open and flowing.
Feb 26, 2014 | Dryers
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Food particles left on dishes. Whirlpool quiet partner 1
You do not have to take it apart to clean it. You can run it a couple of times with dishwasher tablet and it will self clean. In general I recommend rinsing the food off of the dishes and silverware before placing items into the dishwasher. Also, run the hot water in the sink until it gets hot and then turn on the dishwasher. good luck with it.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
253 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
