Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Programming I just purchased a Motorola MTS2000 flashport 2way radio. How do I reprogram?
Why buy a radio you cant program? I suggest you google for Motorola authorized radio shops in your area. Unless you have the software and equipment to do it, you won't be able to. You will also need letters of authorization for any channels you wish to have programed for transmit. If your a HAM or GMRS user be sure to bring a copy of your licence.
Posted on Oct 03, 2007
SOURCE:
How do I set to scan BPR 40
This is only done through use of the programming software and cable. Your radio would need to be reprogrammed.
Feb 07, 2014 | Motorola HT1000, MTS2000, MTX8000/9000...
I need to know the channel my motorola mts2000 flashport is operating on
This type of radio can only be read out by someone with a software subscription and appropriate equipment. This could be an online or local Motorola dealer, a large company, or a municipality.
Best regards.
Dec 11, 2013 | Motorola HT1000, MTS2000, MTX8000/9000...
I need software for motorola mts 2000 flashport
You would need a programming cable as well. This is more likely than not beyond your current level of skill. This software is licensed by Moto, complex and not easy to get over the web. I suggest that first you sit down and make an outline of exactly what frequencies you want to transmit on if you are licensed and what to scan etc and go to a radio shop. It will be worth the money.
Aug 31, 2011 | Motorola HT1000, MTS2000, MTX8000/9000...
How do i program my motorola mts 2000 flashport scanner
Your Motorola MTS2000 is not a scanner but a high-end two-way radio. It requires a computer, special interface box (called a RIB, for Radio Interface Box), the proper cable from the radio to the RIB, and the programming software called RSS (Radio Service Software.)
This is much more difficult than a scanner to program and if not done properly can cause the radio to automatically transmit on frequencies that you are not authorized to use.
Try calling your local Motorola dealer and ask them if they will program it for you for receiving only. They will either flatly refuse or they will be happy to charge you a service fee. Some places are more willing than others.
Dec 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT 1000 programming cable
Sorry to let you down, but the cable will only function with the appropriate Motorola software (and possibly a radio interface box (RIB) if the cable type you have requires one.) Software is only available to dealers. If you are needing reprogramming, it is generally available for between $25-$40 US.
Nov 17, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
MY RADIO
This radio needs to be reprogrammed with the Motorola programming software, this procedures needs to be made by a technitian or someone that has the software, programming cables and the knolagement and the frequencies of course, also the radio has to be the same band of the police.
Oct 26, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
167 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
