Question about HP OfficeJet 6210 All-In-One InkJet Printer
Need printed confirmation fax receipts
How do I get the officejet 6480 to print a fax receipt each time I fax? I will get a printed error message printed if there is a problem but never any kind of printed confirrmation receipt.
thanks!!
Martha
  • Anonymous Apr 23, 2009
    How do I get printed confirmation fax receipts each time I fax?
  • 4 Answers
I had the same problem with my 6210. A different machine, but this may be worth a try. You need to go to the general setup, rather than the fax menu on the keypad. Two pushes of the button takes you to "print reports". Press OK and you go to "Fax Report Setup", OK again gives you "Print Report". You then can toggle with the arrows for the various options. In this case press OK when you are on "sent faxes"
Posted on Apr 26, 2009
  • darlineWWU Dec 16, 2010
    Thanks this was exactly what I needed.
Dell 1815dn Fax confirmation?
U CAN DO A FLEA POWER . \
1. restart the system ,
2. turn off the power / scan/ fax ,
3. unplug all the cable to the system and wall socket and then wait for 20-30 seconds .,
4. connect all the cables and give a try it should work.
Oct 20, 2014 | Dell Printers:Dell MFP Laser Printer...
Won't print ie8 based receipts
It sounds like a configuration error please check all settings and confirm that they are all correct if not correct as necessary. It may also be a conflict between the 2 printers it maybe trying to print to both and cannot due to seeing 2 printers. If you have checked all your settings and they are correct try removing 1 printer and then if it prints on either singularly then it is a error that needs correcting on the settings for your printers to be able to be used together correct this problem and then you should have no problems. I hope this helps.
Sep 12, 2012 | Computers & Internet
How would i get the fax report
from the user manual:
The default fax confirmation setting is Every Error. This means that your
HP Officejet prints a report only if there is a problem with sending or receiving a fax. A confirmation message indicating whether an item was successfully sent appears briefly on the front panel display after each transaction. To have a confirmation printed for every fax, follow these instructions.
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press direction right button until Every Fax appears in the second line of the display, and then press OK.
The HP Officejet will print a confirmation report every time you send a fax informing you whether the fax was sent successfully or not.
Enjoy
Christopher
May 21, 2012 | HP OfficeJet 4255 All-In-One InkJet...
How do I set automatic fax receipt?
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
How do i print a report confirming the receipt of a sent fax
In the main menu under "fax" options you will find the option to print a fax report.
Nov 03, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Q. 1 - When I try to send a fax I get an error message that says: Fax Send Report is set to Off Q. 2 - I have an 1/2 inch black line down one side of any copy I try to make.
1. Usually a "fax send report" just means that you will not receive a "receipt" or "confirmation" that the fax was successfully sent. Changing the setting to off is pretty much just saving you ink & paper. When my fax machine report is set to off, I only receive a receipt if the fax was unsuccessful. However, all fax machines are different and have a mind of their own...so your best bet it to refer to the owner's manual or call the company where it came from.
2. The only thing I can think of is maybe you need to replace the plexi-glass on the copier or do an internal wipe of the underside of the glass. Sometimes the ink can smear from underneath when faxed papers get jammed or printed.
Sep 04, 2009 | HP Office Equipment & Supplies
OKI 24DX - Press ONLINE button to print each page
you have to open your printer icon in CONTROL PANEL
CONTROL PANEL
THEN
PRINTERS AND FAXES
RIGHT CLICK ON YOUR OKI PRINTER
select PREFERENCES
under SET UP and MEDIA size change it to A4
I think this might help you. I'm guessing that you have the wrong size paper selected. And each time the computer needs you to confirm you want to print with a different size paper
I wouldn't phone OKI help line..I was on hold for 15 minutes, then just gave up.
Jul 01, 2009 | OKIPAGE 24 Led Printer
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
FAX CONFIRMATION
-press menu
-press 3, then press 6 to select Print Report
Apr 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
541 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
