Question about Sanyo DS27510 27" TV
Channel programming Hi, I need a solution to lock some channels on the TV, operational only upon entering a password. It is kind of parental lock, but not rating based...it should work even without ratig information. Thanks.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
If you want to much about remote please go to www.remotes.com you will get all answers.
Posted on Oct 01, 2007
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
Admiral code for JSJ12800 Vchip is activated don't know the code?
Usually you need to go to menu option and then then parental control. When display asks for secret number,Press and hold volume up and channel down simultaneously until message is cleared.This turns off parental control and clears the password.
Note - You must press the volume up and channel down buttons on the TV, not on the remote.
If the problem persists, revert and i would be able to search exclusively for this model.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 25, 2010 | RCA F27664 27" TV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
V-chip or parental control
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
End of manual text.
try this thx nick
Feb 07, 2008 | Curtis-Mathis CM32010 TV
Lost parental password
GET TO YOUR SON THE PASSWORD HE ENTER AND WHEN ENTER IN THE PARENTAL AREA SET IT OFF.
Jun 07, 2007 | RCA F27664 27" TV
Most of the stations are blocked!
Welcome to the wonderful world of the vchip. Making better babysitters through tecnology. From what I understand the control if placed in a ram and cannot be reset without the password. I would call RCA and talk with a tech there might be a generic unlock code like on the old playstations. You may have to prove you are the rightful owner and over the age of 18.
Jul 30, 2006 | RCA E13319 13" TV
Sanyo DS27510 27" TV Logo
187 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
