Question about Roper REX4634KQ Electric Dryer
Electric dryer drum belt configuration - Roper REX4634KQ Electric Dryer
  • Roper Master
  • 528 Answers
TRY THIS VIDEO :)
http://www.youtube.com/watch?v=47hZkkV6CWk&feature=related
Posted on Jan 05, 2010
Put new tensior on sounds like it rubbing on something what did i do wrong
did you make sure the lip (back) of the drum was over the drum rollers and glides were in place:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
belt configuration:
http://www.applianceaid.com/images/belt-config.JPG
Dec 03, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore solid state dryer. was squealing while running. now drum stops and starts. still squeals
belt, idler pulley, drum glide/rollers:
belt/idler pulley:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
rollers/glides:
http://www.partselect.com/dryer+replace-glides+repair.htm
belt configuration
Dec 03, 2010 | Kenmore Dryers
How do I replace the dryer belt?
sorry see the make, here is how u do the job
Instructions Things You'll Need:
  • Screwdriver with interchangeable bits
  • Putty knife
  • New dryer belt for GE Hotpoint electric dryer
  1. Step 1 Unplug the dryer and pull it out from the wall. Take out the upside-down screws in front that hold down the top. In older Hotpoint models, they will be under the rim of the top in front. In newer models, they will be on the inside of the dryer door opening, facing up. Slide your putty knife under the top rim to pry it up and get your fingers under it. Lift the top off the machine and set it aside.
  2. Step 2 Take out the screws that hold the front of the dryer in place, which will be on the upper inside of the box, on either side, facing toward the front. Pull the dryer front off. Keep the side with the wire connections next to the dryer (so you don't have to disconnect the wires) while opening the other side away from it like a door. The wiring side will vary.
  3. Step 3 Slip the belt off the dryer drum from the front. It won't come out completely; it will be held in one lower corner by the motor assembly.
  4. Step 4 Remove the access panel on the lower part of the back of the dryer by removing the screws. Access the motor unit. Note the configuration of the belt in the pulleys, then slip the belt off the pulleys by pushing the larger pulley forward.
  5. Step 5 Slip the new belt onto the drum from the front, with the ribbed side against the drum. Re-string it on the pulleys from the back, in the same configuration as the old one. Manually turn the drum several revolutions to make sure the belt is straight.
  6. Step 6 Put the rear access panel back on with the screws you took out. Close and re-secure the front and top (in that order) as they were before. Plug in the dryer.
Jul 07, 2010 | Hotpoint Dryers
Drum won't turn
Your dryer uses a belt wound around a spring loaded pulley and, around the middle of the drum and, around the motor pulley to turn the drum. If you feel capable of fixing ths yourself: Unplug the dryer, if it is gas or, electric. if it is gas: shut off the gas line to the dryer then remove the gasline; next pull the dryer out from the wall and, remove the back panel. Once you do this you will see that the belt has fallen off both the motor pulley and, the spring tension pulley. put the belt back on so that the belt is tight around the drum and, the drum will turn again.
Apr 05, 2010 | Whirlpool LER4634J Electric Dryer
The belt fell off the dryer how does it go on
The belt usually comes off the rollers if you turn the drum by hand. The link below will show you the belt configuration for most Maytag models. Maytag machines are made in several configurations.
Dryer belt configurations
Sep 30, 2009 | Maytag Dryers
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
I need the Kenmore 110.66712 Drum Belt configuration
You can go to Sears PartsDirect and see an exploded view of your dryer.
Dec 29, 2008 | Whirlpool LER5636P Electric Dryer
New dryer belt configeration
loop belt around drum gather belt at bottom feed left to right through bracket opening pull up and fit belt around motor shaft flat side of belt will be on bottom side of pulley doward pressure of pulley will put tension on belt
Jun 18, 2008 | Whirlpool LER5636P Electric Dryer
Roper REX4634KQ Electric Dryer Logo
116 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
