Question about Maytag Legacy Series Top Load Washer
Maytag A210 washing machine water spill
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} My old A210 stopped agitating (with smoke rubber and screaming sound) after I moved it around to replace the water heater. So I took its front cover off and tilt the unit to dismount/remount the belt, pulley, spring and most of parts under the bottom. It works again with a new issue now. When it works in agitate phase, it spins so fast that water comes out from the top of the tub, accumulated at outer tub cover, eventually flow along the outer tub and make a mess. I notice there are 6 holes on tub cover, but water is just spilling out too much to drain back in tub.
Any idea what I should check next? Appreciate your advice.
  • 11 Answers
SOURCE: Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
Posted on May 20, 2007
SOURCE: Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
Posted on Oct 23, 2007
onthejob5130
  • 640 Answers
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Posted on Jan 03, 2009
  • 653 Answers
SOURCE: Maytag MAV7650AWW spins during agitate cycle
If the tub spins during the agitate cycle, the the problem should be in the timer. It sounds like everything else is working properly. A new timer is fairly expensive, but your Atlantis is fairly new so it should be worth the money.
Posted on Feb 28, 2009
Healeyman
  • 1198 Answers
SOURCE: washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
Posted on May 04, 2009
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
My Maytag washing machine does not really agitate
It sounds like the belts need replaced. There are 2 of them. One drives the transmission, and one drives the belt. They should both be replaced. Also, there are rollers on the motor bracket that wear. Make sure the motor moves smoothly back and forth in the bracket.
Jan 28, 2010 | Maytag Washing Machines
My maytag washing machine spins but won't agitate.
sound like the agitator motor went out the way to fix this is to take the agitator out and replace it along with the motor
Sep 01, 2009 | Maytag Performa PAV2200
Washing machine was making noise when agitating & spinning
May 04, 2009 | Maytag PAV2300 Top Load Washer
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Washing Machines Logo
365 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
