Record player not working
This old hi fi has no record deck rotation. Record player door opens/closes ok, but record not turning after pressing play Sharp VZ3000E
  • allanwhipp Apr 20, 2009
    Thanks for the help, but this turntable is a direct drive
    and there is no belt involved.
    It seems to be a servo fault.
    anyway, thanks again
    Sniper:
  • 86 Answers
Hi Allan,
Unfortunately it sounds like the belt either broke or is slipping. If you're up to it, you can order a replacement belt from a few different places online. As I haven't messed with a turntable in years, I can't make any personal recommendations. A quick google search returned this company, though... http://www.turntableneedles.com/
You'll need the current belt measurements before you order a replacement. And, disassembling the unit will confirm if the belt is broken or just slipping. (Or, better yet, slipped off the pulleys!)
Keep in mind that replacing the belt can be a daunting task.
Posted on Apr 20, 2009
  • OnlyOneN
    OnlyOneN Apr 20, 2009
    Sorry I was off on that one... I found someone in the UK on a forum who said he had the same unit and replaced the belt.
Hello, I have a TEAC D200, but I cannot record. I have used different CDs and when I press dubbing it says no disc. I found a blank disc that it recognized, but it does not record when pressing dubbin
1. check right (supported) sort of cd's you say rw is ok, check type!
2. such old model possibly has wear-out on laser or else
3. lots of dust inside; use @ least cleaning - cd... or equivalent;
good luck
Ganimidis
Dec 29, 2014 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
I have a Kenwood KR V6090 tuner amp. Can anyone please tell me if I need a record deck with or without a pre amp fitted.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
Dec 12, 2014 | Kenwood Audio Players & Recorders
I have an old record player. It was made in the 80's according to my mom. I have recently started to use it( it hasn't been used since 86). With the exception of 45s, the record player will only play side...
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
Aug 24, 2014 | Audio Players & Recorders
I have a Hacker Gondolier record player fitted with a Garrard 2025TC record deck. The record deck suddenly made a light whining noise then stopped rotating altogether. The belt is still intact. Will the...
First check to see you can turn the motor by hand. If it is stiff there's something wrong with the motor. If OK then have a look at the motor. If it works on 12 volts or under, you can attach a 9 volt battery PP9 type to it. If it's 6 volts, use a 6 volt battery! (You might have to remove any wires going to the motor to do the test). This should cause it to spin. If it doesn't it's dead. If it does check the voltage supply to the motor. Also check for broken plastic parts anywhere on the deck.
Dec 08, 2010 | Audio Players & Recorders
I have a Technics Hi-Fi System. My Record Deck
I have them listed on ebay as item 250390631634 for £7.25
Feb 09, 2010 | Audio Players & Recorders
Cassete deck will not work, I put a tape in deck 2 and hit the record button and all it did is started to make a clicking noise. Next I tried to take tape out and the door would not open. I forcefully...
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Jun 05, 2009 | Aiwa NSX-A767 Shelf System
Tape deck door problem
The mechanism would not have reset to allow the door to latch on. it could be a possible failure of the main/dirve belt. you will also have to check if the hinges are broken or if any freign particles have logged in. Removing the deck mechanism and changing thebelt will require a little expert work and so be very careful in removing.
Apr 23, 2009 | Audio Players & Recorders
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Oct 10, 2008 | Audio Players & Recorders
DVD tray will not remain closed
Try this. With the tray door still open and the power on, press and hold the play button until the door closes. If you hear the disc loading the door will remain closed for play and record.
Have the same problem - works for me!
Dec 15, 2007 | iLO DVDR04
147 people viewed this question
 Grubhead
Grubhead
