Question about Gateway GT5220 PC Desktop
No icons, start menu, taskbar, explorer not working
Haven't used pc in awhile. Turned on went thru boot up ok typed password and said loading settings, shows no taskbar, no start menu, no icons, only shows desktop wallpaper. Ctrl-Alt-Del will bring up task manager. Can get into most programs except internet explorer. Under program files found iexplore.exe, Tried that and pops up then closes without saying anything. Any suggestions would be greatly appreciated.
  • jmbayler2003 Apr 20, 2009
    Cannot do anytype of backup att. keep getting explorer.exe has encountered a problem and needs to close.
  • 432 Answers
Backup your data and do a repair install - might take a while longer but at least you know it will clear any issues.
there are a number of things you can do to fix it but will most likely take a lot longer
Posted on Apr 20, 2009
  • Shane Russell
    Shane Russell Apr 20, 2009
    reboot into safe mode ( restart and keep pressing F8 ) it should then prompt you with a dos type menu ( use the up and down arrow keys on the keyboard to select the relvant option ) and then press enter.
    You should then be able to backup your data and from there use your installation disc / the disc you got with your computer to set it to factory defaults
What is PCProtect?
PCProtect is malware. What is PCProtect exe . I would boot up in Safe Mode again, or Normal if you have to, and bring up Task Manager again (Ctrl-Alt-Del) and check to see if explorer.exe is running. If not, Click on File in the Task Manager toolbar, select New Task (Run), and type explorer.exe in the Open box and click OK. If all goes well, your icons and Start Menu will appear and you can start cleaning up. Otherwise, you could try again and type appwiz.cpl in the Open box to bring up the Programs and Features to remove any bad programs you may find. Malware removal can takes years of experience, so I will leave it at that to try for a starting point.
May 03, 2014 | Dell Precision Computers & Internet
Dell D610 nothing but background image
Hi.
The laptop seems to have a problem with explorer not loading properly (this is the program which loads up the taskbar, icons etc)
Hold down Ctrl, Alt and press the delete key. Dependent on the operating system it will either go to list or load up Task Manager, ether way you need Task Manager.
When Task Manager loads up in the top left corner of the window you will see File, click on that and select New Task (run), click on that and in the box type explorer and click OK, The desktop should now load up.
After that make sure you perform a system restore by clicking on the start menu, accessories, system tools, system restore and take the laptop back to a time before this happened.
Regards.
Jan 29, 2013 | Dell Latitude D610 Notebook
I have an HP1110n....It acts like it is booting up, but I only see my screen background pic. No icons show up. The disk spins and is doing something, but it won't display ANY icons ! Help !
This happens when Explorer (the file manager - the program that makes all the files visible on the screen) doesn't starts at boot. Press Alt + Ctrl + Del to open Task Manager. Click File, click Run and type explorer. Click OK and the icons and the taskbar will appear. If it doesn't start or it's faulty in any way you will have to reinstall Windows.
Jul 31, 2011 | HP Pavilion a1110n (PX743AA) PC Desktop
Missing task bar - running vista
Sounds like explorer.exe is not running:
1. Hit Ctrl + Shift + Esc at same time.
2. Windows Task Manager should open.
3. Hit File on top menu.
4. Select New Task.
5. Type explorer.exe and hit OK
That should bring your task bar back.
Jun 02, 2010 | Microsoft Windows Vista Home Premium...
Windows did not appeared, only mousepointer was appeared. The icons on destop, taskbar and start menu are not appeared. What are the best solutions Tank you!
Press Ctrl + Alt + Delete together and Task manager will be opened. Click on file -> New task . In the box type explorer.exe.a nd click ok. If this doesn't works boot your computer from XP disk and run repair from disk.
May 27, 2010 | Microsoft Windows XP Professional SP2
Volume Icon has disappeared.
First, right click on the taskbar and select Properties from the right click menu.
Alternatively, you can go to the Control Panel and type the word 'taskbar' in the search box from the upper-right side. Once the search results are loaded, click on the link that says 'Customize icons on the taskbar'.
The Taskbar and Start Menu Properties window will show up on your screen. Here, go to the tab called Notification Area. In the System icons section check the Volume box and click on OK.
The Volume Mixer icon will now show up in the notification area of your taskbar
I hope that this information was helpful and thank you for contacting the experts.
Jan 18, 2010 | Toshiba Satellite A65-S1362 Notebook
No icons or start button
ok, press the Ctrl, Alt & Delete button, to start the task manager
Applications tab, bottom right "New Task" click this
type "explorer" then ok
Icrons and start button will be back
hope this helps
Richard
Nov 11, 2009 | Dell Computers & Internet
Satellite A85 running XP Home...boots to desktop theme, but no icons, start button, or taskbar Don't want to use my Restore disk as it will erase the HDD and I'll lose everything. Suggestions?
Try booting to the Safe mode; this will load Win but with minimal junk loaded. You can access the menu to choose boot mode by turning on power and immediately start tapping the F8 (sometimes F5 instead) key. You should get a short text menu with the possibilities listed. If you can make it that far, open the Start menu, choose 'Run.' Enter:
rstrui.exe
click 'OK.'
This starts the restore routine and, if you haven't had it turned off, you can restore your system back to a calendar date (not too recent, choose a couple of days back) when it was still working.
You will lose no work other than Win and AV updates that have occurred since that date.
This will often make everything OK again; with the reminder that it IS Windows.
Good luck-
Sep 30, 2009 | Toshiba Satellite A85-S107 Notebook
Lost connection
If your computer is working ok can you press Ctrl+Esc together to open the start menu and is all your programs listed. if so then go to settings - control panel - click on display - find your advanced option and untick the option for displaying the desktop as a URL...
you can also try simply right clicking on the desktop and tick the option the see all icons but that will not show your tast bar only your icons.
Feb 20, 2009 | Acer Aspire One AOA150-1570 Notebook PC
I cannot see my desktop icon taskbar and start menu. though i opened it by pressing ctrl+alt+del and going to task manager and running explorer. but when i shutdown or restart my computer i use to go...
Press CTRL+ESC
If your taskbar reappears, then it was just accidentaly been resized and repositioned somewhere
IF that doesnt work :
press CTRL+ALT+DEL to run task manager. On the File menu, select New Task (Run). Type in "explorer" and press OK.
Feb 18, 2009 | ASUS A9RP Notebook
Gateway GT5220 PC Desktop Logo
241 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
