Question about Linksys RangePlus WRT100 Wireless Router
Lost CD I've lost the CD to my WRT100, and had to reformat disks and reinstall windows XP. I'm using an AT&T/SBC 2WIRE 2700 modem I've tried the following two set of instructions without success. Any ideas are appreciated. INSTRUCTIONS 1 I. Reset the router. 1. Press and hold the reset button for 10 seconds. 2. Unplug then plug back the power adapter to the power source. II. Just follow these simple steps to configure your router: 1. Connect the PC to the port one of the router then restart it. (This PC should be the one that can get online if directly connected to the modem). 2. Go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP). 3. When "Internet Explorer" opens type http://192.168.1.1 into the "Address" bar and click on Go. 4. The log-in window will appear. 5. Skip user name and type admin (admin is the default password) as the password, and click OK. 6. Go back to the "Basic Setup" tab and set the "Internet Connection Type" to PPPoE. 7. Enter your username and password given by the Internet Service Provider. 8. Look for the LAN IP which is 192.168.1.1. 9. Change the IP address to 192.168.2.1 then save the settings. 10. Shut down everything for 2 minutes. Connect the cable from the modem to the Internet port of the router. 11. Power on. (Starting from the modem then the router and lastly your PC). 12. Access the setup page using the new IP 192.168.2.1, click on Status tab and hit Connect. III. Click on the Wireless tab: Wireless Configuration: Manual Network Mode: Mixed Network Name (SSID): (create your own) Radio Band: Standard Wide Channel: (default) Standard Channel: (default) SSID Broadcast: Enabled Save the settings. Click on the Wireless Security sub tab: a. Set Security Mode to WPA Personal. b. Set Algorithms to TKIP. c. On the WPA Shared Key field, type your desired WPA Key which must be between 8 and 63 characters in length. d. Set Group Key Renewal to 3600. e. Click on Save Settings. IV. Using an Ethernet cable, connect the modem's Ethernet port to the router's Internet port, leaving the computer hooked up to the router. INSTRUCTIONS 2 I. Reset the router. 1. Press and hold the reset button for 30 seconds. 2. Unplug then plug the power adapter back to the power source. II. Configure the router. 1. Connect a computer to any of the LAN or ethernet (numbered) ports of the router. Use the computer that can access the Internet when connected directly to the modem. Disable the firewall on the computer. 2. Make sure that the corresponding LED for the numbered port is lit. (The modem should not be connected to the router yet). 3. Double-click on Internet Explorer. 4. When Internet Explorer opens, type http://192.168.1.1 on the Address bar and click on Go. The log-in screen window will appear. 5. Skip user name and type admin (the default password) as the password, and then hit Enter. 6. Set the Internet Connection type to PPPoE and then enter the user name and password provided by your Internet Service Provider. *The user name can be in an email address format (user name@AT&T.net or .com), It should be the user name and password that you use to go online when directly connected the modem. 7. Select the Keep Alive option. This will ensure that your connection stays active at all times. 8. Save settings. [11:00:08 AM] Lyndie (29179): III. Using an Ethernet cable, connect the modem's Ethernet port to the router's Internet port, leaving the computer hooked up to the router. IV. Power cycle: 1. Shut down the computers. 2. Unplug the power cable of the router, followed by the modem. 3. Wait for one minute. 4. Plug in the Broadband modem?s power cable and wait for the lights to stop blinking. Then plug in the router's power cable. 5. Finally, start up the computers and test the Internet connection.
  • 83 Answers
To get my connection to work, I had to configure my Netopia DSL modem for Bridged Mode and let my router take care of the routing and address assignment. I would also try to get a working connection before configuring security. You can always do that later. You have the order of powering up you equipment correct. Read this link. It works for me.
http://www.dslreports.com/faq/15855
Posted on Apr 22, 2009
2 people on modem . router 2wire... and when one is one , other gets kicked off can't fix help
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
if you are with At&T AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 29, 2011 | AT&T High Speed DSL Modem
How do i setup my 2 wire router with dsl modem to network iat home
Try this links:
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
How to configure 2wire 2701?
Try this links:
Aug 11, 2011 | 2wire (2701HG-B) Wireless Router
How do I add additional devices (laptop computer) to the router?
Try this links:
Aug 09, 2011 | 2wire (2701HG-B) Wireless Router
Trying to hook up 2wire modem to internet provider?
there is a cd-less install or Greenlight technology in it. it will automatically startup once you open a browser, (preferably IE. However, if you don't see it, try pushing the reset button at the back of the unit for 30 sec. open IE, then you will see the installation page.
NOTE: make sure you know what your username and password is... for authentication purpose...
links that may help: 2 WIRE Activation keys
http://www.2wire.com/?p=268
Try this links:
Jul 20, 2011 | 2wire (2701HG-B) Wireless Router
How do I get my brother 1250 printer to print automatically? It used to print automatically when I clicked on Print but now I have to go into the ?Print Options and click on the Hold button twice before...
2wire lost password reset 2wire dsl modem sbc 2wire router modem unlock 2wire 2wire 1701 hg ... 2wire homeportal 2wire 2700 2wire can't get ip address .... default 2wire password 2wire modem att white paper 2wire gateway ip address .... usb 2wire hpna linux working for 2wire wrt350n and 2wire modem ...
groups.google.com/group/alt.languages.catalan/.../a1f780eac37721f2
The 2Wire HomePortal is a wired solution that offers subscribers hassle-free, ... Cisco-Linksys EtherFast Cable/DSL Router with 4-Port 10/100 Switch ... 5.0 out of 5 stars I could not ask for anything better than this., December 17, 2006 ... I waisted my money. My tech guy said it was an older generation unit, ...
www.amazon.com › Video GamesMac GamesHardware
Jul 20, 2010 | Brother HL 1250 Laser Printer
How do you make an Sbc 2wire 2700 modem wireless?
2wire is a kind of modem/router. So you don't need to use other hardware.
Mar 26, 2009 | 2wire 2700HG-B Router (2700HGB)
FORGOT PASSWORD
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} In addition to reinstall your system, the easiest way to solve the
problem is to use some Windows Password Reset program. The
program will enable you to reset the password to "Blank" with no
-reformatting or installation. Do all the job for you automatically. It's worth a try.
http://www.resetwindowspassword.com
Jan 03, 2009 | Acer TravelMate TM2480-2705 Notebook
2wire wireless usb adapter installation for desktop
elomarcillo1,
You are attempting to install a (brand name) 2wire wireless usb adapter, normally the SBC DSL CD is ONLY what you would use to set up your SBC DSL modem. You should have a specific 2wire CD that you put in your CD Drive when you want to install the 2wire wireless usb adapter. Can you locate this CD?
-ms
Nov 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Linksys RangePlus WRT100 Wireless Router Logo
195 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
