Question about Canon PowerShot A530 Digital Camera
LCD LENS WHEN I TURN THE CAMERA ON, THE SCREEN IS COMPLETE BLACK. I CHANGED THE BATTTERIES. I CAN TAKE A PICTURE AND VIEW IT ON THE COMPUTER, BUT I CANT SEE ANYTHING IN THE LENS OR SCREEN. I ASKED CANON WHO SUGGESTED THE LCD WAS CRACKED AND TO SEND IN FOR ESTIMATE TO GET IT REPAIRED. I ONLY HAD IT A YEAR AND IT HAS NOT BEEN DROPPED. DO YOU HAVE ANY SUGGESTIONS OR TROBLESHOOTING I CAN ATTEMPT?
  • Anonymous Dec 24, 2007
    Hi I have the exact same problem and it worked 2 days ago - I am stressing because tomorrow is christmas.
  • 69 Answers
Canon would appear to be correct with this diagnosis
Posted on Sep 24, 2007
SOURCE:
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
Black Screen
ok...open up the camera, remove battery and card for photos...then place battery in again, and turn on..see if that helps at all
Mar 09, 2008 | Nikon Coolpix S4 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
A85 camera LCD shows up with pink and black lines every time a picture is taken. LCD screen displays the camera icons on LCD screen but will not take anymore photo's. Lens used to view picture status...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 06, 2010 | Canon PowerShot A85 Digital Camera
I cannot see anything when in camera, film, or view mode. When I snap a photo, it sounds like a picture was taken and the flash still goes off, but nothing is displayed on the screen. Only when I attempted...
Does it show pictures on the computer or is it black images, if they are black, your cameras lens cover could be stuck, it opens up when the lens is fully open, dirt-sand and dust or old grease causes the problem. otherwise your LCD on the camera could be off by mistake, (Do a camera reset) or a bad LCD
Oct 27, 2009 | Canon PowerShot SD600 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Black LCD screen but Lens view & record fine
It is possible you have turned the LCD screen off - Go to the settings in the camera and reselct the LCD Screen on.
May 11, 2009 | Cameras
LCD Screen
cant be done you need the new 450d which has live view so you view the lcd when taking the picture
Oct 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
LCD wont show the View and No picture
CCD failure most likely. Format the card then try again or a new card. Kodak customer support for more info
Jun 08, 2007 | Kodak EasyShare DX4530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
