Question about Philips J44414
SCI4750/27 Ok, my CD flat out does not work on my computer, or any, While sure I could go try a whole other camera, probably should I don't got the money to shuffle around... I need the drivers to at least see if the thing works, but I can't find them anywhere... Philips's home page says that it isn't even a product??? Help?
  • 6 more comments
  • TechnoUnsavy Sep 21, 2007
    Ok, see that's just it, I've given them serial#'s and the product code right off the box. Still nothing.
  • Wayne Coskrey Nov 07, 2007
    Nope. I am a computer tech with the same problem, and the only model number on both the box the webcam comes in and on the webcam itself is "SIC4750/27." After going for broke and performing the usually unwise step of plugging the webcam in before running the software that installs the driver, Windows Vista Home Premium automatically downloads software for what it is calling "Ezcam III," with the manufacturer identified as "Surplus" instead of Philips. Everything seems to be fine with the webcam using this driver, checking things out using "Webcam Diagnostics" freeware available from the author's website: http://noeld.com. He also has a number of other freeware programs that can help you in installing a webcam. Good luck!
  • soniablade27 Nov 26, 2007
    No its the right part number ..I have the same problem and I bought mine at walmart sic4750/27
  • ouahbi22 Nov 26, 2007
    usb devise not recognize
  • Anonymous Dec 15, 2007
    Well I need to get the driver so as can install this webcam model SIC 4750/27. I bought it Wall-mart and this is the only number i the box
  • Anonymous Feb 13, 2008
  • Anonymous Apr 30, 2008
    i need
  • briix3lovee Jan 04, 2009
    cd doesn't work
Vista Drivers?
Posted on Oct 12, 2007
    Sergeant:
    Champion:
  • 293 Answers
You have the wrong part number usually they use SPC**** on their webcams
Posted on Sep 21, 2007
SOURCE:
Mpcheeseman it wont ever turn my cd on now so i cant boot from it
Oh--now I understand. You are using the restore disks for your computer.
It sounds like you did the correct thing, but try this:
Do the whole thing over. After the last disk is finished and it wants you to restart the computer, remove the disk from the drive and see if it boots OK. It almost sounds like you were told to reboot the computer and when it started it asked you to press any key to boot from the CD and you did. Don't do that--just let it go on its own. Let us know what happens.
Oct 15, 2011 | Acer Aspire 3004WLCi Notebook
I have a Canon A560 camera. It takes pictures and I can download them to my computer OK. But the LCD screen is black, I don't see any display at all. Pushing the display button does no good.It got...
If your LCD doesn't light up then it's either the backlight or the LCD, you can open up the camera and check the cables before buying any parts. Some LCD screens come with the backlight, some don't; not sure if this one does or not.
IF it was water damage, you probably have corrosion on the main PCB and won't be able to fix it without replacing the board... open it up and check for corrosion!
Hope this helps.
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot A560 Digital Camera
I don't have a problem with my camera, but I need an instruction book for my easyshare C195. Is it possible to obtain one?
Are you sure it is not on a CD (if any) that came with the camera?
If not best solution is to Google it.
Go to Google and type in Kodak Easyshare C195 manual and click enter.
You will get a list of alternative solutions.
The simplest is probably a PDF version you can download and keep on your computer.
Monst manual are quite long and expensive to print off - ink and paper.
Jul 06, 2011 | Cameras
The sound is just a high pitched buzz
Hi Bill, most issues such as this are due to inaccurate connections in the back, so be sure you don't have a video RCA connection going to the "audio in" jack.... or something similar.
Try investigating the sound while using "over the air" tv or through an old Coax cable\antenna connection.... If it works correctly from that source then you are probably OK...
Jun 09, 2011 | Televison & Video
I push the power button It doesn't boot all the fans come on the light come one and a second later it off, then it tries again, it keep trying to cycle but can get anywhere. I have just assembled this...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 10, 2011 | Computers & Internet
Monitor doesn't show anything everytime I boot my PC. Power produces a clicking sound. I checked with the wires, sometimes the monitor does come back to work and sometimes it does not.
don
Feb 23, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Processor fan is running, display nor work computer is not boot, memory test is OK, video card test is OK,
don
Feb 18, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
When i turn on my computer, processor fan starts ok , I get bip, but system doesn't start, no single message or simbol on the screen. I removed the cover and shaked processor fan, after it starts and whole...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | ASUS P4P800-X Pentium Motherboard
My fujifilm finepix camera gets stuck when i look through my pictures, so when i go to my library, my whole camera gets stuck and i have to take the battery out to turn it off. it still takes pictures, and...
The card is probably defective.
But before buying a new card, try to format the card in the camera. Make sure you have saved all images first. Formatting will "reset" the card and delete all images.
To format the card: Menu/ok, Setup, Format, OK
Feb 18, 2010 | Fuji J150w Digital Camera
My sanyo digital camera model- vpc5500
when i try to transfer photos to my printer camra turns off printer is working ok any ideas
Oct 24, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Philips J44414 Logo
399 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Herb Box
Herb Box
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
