Question about HP Color LaserJet 2600n Printer
Error 55.1 and also language need to change english
  • 432 Answers
Get the relevant firmware update from the hp website and update the firmware ( I think there is a firmware update manager for hp printers so maybe check that out )
Also with regards to changing to english you may be able to do that through the web interface using its ip address or if you do the following
Set the default language and paper size by performing the following:
  1. To start press the button (CANCEL JOB) to make sure that the printer is on ready state.
  2. Press the button (SELECT) to enter the main menu.
  3. Press button (RIGHT ARROW) one time to enter on main menu / system setup.
  4. Press the button (SELECT) twice to enter the system menu / language.
  5. Press button (RIGHT ARROW) until you get the desire language.
Posted on Apr 20, 2009
My Bizhub c252 is displaying in a foreign language and I prefer English because I understand only English and it is also reading error code C-D370
To change the language
1 press the utility/counter button
2 touch user setting the top left button on the touchscreen
3 touch users choice the left button on the touchscreen
4 under the tab 1/6 the second button on the touchscreen is langauge selection touch this button and you can change the language
if you have recently changed the nv ram and this is what caused the language to change on the machine then post a follow up and i will post the instructions to change the language for this it is a different procedure.
Jan 15, 2015 | Konica Minolta bizhub C250 All-In-One...
How do I change the audio language on my vizio from spanish to english?
solution
you can change your
Spanish to English language.
at first you in menu to language setting and change your language.
Thank you
Send report :babul_jpi90@yahoo.com
Jul 27, 2011 | Televison & Video
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
Dec 07, 2010 | HP LaserJet 4500 Printer
I am using a netgear stora network drive and whenever I try to access it remotely I get a language error code window. It says, Language Error The following error occurred: Unable to load...
You get this error if you set up through the browser window instead of the CD software. To fix change your language in the user preferences to another language, save and then change back to english.
Nov 25, 2010 | Computers & Internet
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
Internal DRS error 1500:c0:3001
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
Aug 28, 2009 | HP LaserJet 3600n Printer
Internal drs error 1500:c0:3001
Try change the OCR language.
I had the same problem (HP Deskjet F4280, error code 1500:c0:3001) scanning documents with danish language to PDF and OCR language set to English. Changing OCR language to danish solved the problem.
PaulPS
Apr 13, 2009 | Office Equipment & Supplies
Language Problem
It is in the settings menu ,after choosing settings you would choose language, but that would be in English.
If you go to the home screen, the Settings menu is usually the 6th entry from the top. After choosing that, see if you can click individual items to see if you see an entry for "English" to change it.
Apr 05, 2009 | Apple iPod nano
Non english display cs 5035
Hello sir; Try to return to english first, the procedure as follow;
1, press the keys in order "10871087".
2, enter 018 press "start".
3, you can checksum for the ROM,reset main board, change language.
4, enter "001" press print.
Hopefully can resolve your problem, good luck!
Jan 07, 2009 | Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
