TILLER WILL START/RUN BUT BLADES DON'T MOVE..TILLER PART DON'T MOVE?
MTD21AH413B129287-424
Hello, W/D here.
The motor drives a belt, and the belt drives a pulley that causes a chain to drive the tines (blades). For the belt to drive the tines, an idler pulley has to put tension on the belt. This is moved into position by a lever that pulls the pulley into tension on the belt, and tension is maintained with a spring when the lever is locked into place.
1. Make sure that the tines will rotate with the belt off. If there is difficulty, check for debris holding the tines (roots, etc.). If necessary, remove the cap covering the chain cover inspection port, and with the machine tilted back, observe for proper operation of the chain while moving the tines by hand. Lubricate the chain according to your manual. If your chain is not working properly, disassemble down to the chain case, and inspect the chain and sprockets. Chain is radily at places like Motion Industries, WW Grangier, or a bicycle shop. Often overlooked, check that the pulley set screws are tight, and causing the shaft attached to it to actually rotate. Check the pins and locking cotter pins in the tines, make sure that they are pinned to the shaft.
2. Check the belt. An old belt can stretch to the point where it will no longer work. The "V" belt can also wear down to where insufficient friction can be applied to the driving or the driven pulleys to cause it to rotate.
3. Check the condition of the idler pulley and spring. Make sure that the lever places tension on the belt. It should be somewhat difficult to engage the idler pulley when the belt is new. You may have an adjustor on the idler that will tighten the belt.
Best regards, --W/D-- Please provide feedback for our solutions so that we may continue to improve in helping others. Thanks.
