Question about Toshiba 36A60 36" TV
Remote sensor the buttons on the front of the Tv work but when I use the remote it does not work I changed batteries even bought a new remote but I think that the remote sensor needs replacement. Please help
  • kimberly gilbreath Mar 05, 2008
    My remote quit working on my ZenithD32D51 tv. We were mostly using the satellite remote to work the tv, but it no longer works on the tv either, though it still works on the satellite receiver. The buttons on the tv work fine.
  • amh1 May 02, 2008
    Toshiba and/or Comcast remote control no longer turns TV on/off and will not adjust volume. We have been using Comcast Universal Remote with this TV for several years. We have replaced the batteries and exchanged Comcast remotes. The problem seems to be with the sensor on the front of the TV set. Is this a possibility and how can it be repaired? The TV was purchased June 2001.
    Genius:
  • 1,694 Answers
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Posted on Nov 08, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
The buttons on the front of the Tv work means your tv has no problem. but when I use the remote it does not work problem in remote only. even bought a new remote is it same 7 IF YOUR ANSWER IS YES then as you said there is a problem in sensor circuit or loose contact there in system control ckt. good luck.
Posted on Sep 28, 2007
SOURCE:
Tv remote wont work even though new batteries are put in.cannot change channels or volume or even turn the tv off or on
Try opening up the unit and cleaning the contacts and bottom of the buttons with a q-tip and a bit of rubbing alcohol. Over time the oil from your fingers gets inside and creates a film between the contacts and the button so the circuit will not complete and your buttons stop working.
Feb 17, 2015 | LG RU-42PX10 42 in. HD-Ready Plasma...
My Mitsubishi projection TV will not produce audio or video
Two things are involved to cause that problem, tv remote control and remote sensor in tv.
Upon verification of remote working, it would be confirm that remote sensor in tv is defective and need to be replaced.
Remote control sends infra red light signal to tv and we can not see that light with naked-eye, so need digital camera or cell phone camera to see it by watching remote front through camera, press any keys on remote, if you see infra red light is blinking in remote front that means remote is working and remote sensor in tv will be replaced.
If no light blinking on pressing remote buttons confirm that this remote is defective and buy new remote.
Let me know if you have additional question.
Thanks.
May 31, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Scott TV remote not working
yes the sensors on all sets go bad and the remote signals will never get to the eprom chip that takes the signals and processes them
Dec 29, 2008 | RCA 32V420T 32" TV
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Remote will not function with TV
If two remotes do not work. I would say the IR sensor on the front panel of the TV might be defective.
Can you provide an exact TV model number to try to locate an IR sensor part suppier?
Mar 10, 2008 | Toshiba 36A43 36" TV
Even new remote won't work
when you purchased the identical remote did u ask the supplier if you have to program the new remote or was it preprogrammed at the factory I would start here first.
Jan 16, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Demo mode wont shut off
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
May 21, 2007 | Toshiba 32A33 32" TV
Remote Won't Work! Problem with TV remote receptor?
Try unplugging the set for 12 to 24 hours. if that does not work, theres a problem in the remote sensor circuit or the microprocessor circuit. its going to need a pro to fix it as it meeds trouble shooting.
Sep 05, 2006 | Toshiba 32AF41 32" TV
Toshiba 36A60 36" TV Logo
748 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
