Question about HP iPAQ H2210 Pocket PC
Battery issue I tried to turn on my h2210 after one year of not using it. I charged it for eight hours first. It will turn on when plugged into AC power. The second I unplug it, it dies. Little help.
    Problem Solver:
  • 16 Answers
Re: Battery issue
Posted on Jan 26, 2008
0 characters
3 Points
Tmobile dash isn't turning on
  1. Verify that the OEM Charger and Battery are being used.
    • Only the AC charger, Car charger, or USB data cable that came with or was created for the device should be used; others can damage the device and/or battery.
  2. Is the device warm?
    • When using the device for prolonged periods of time, such as when you're talking on the phone, charging the battery or browsing the web, the device may become warm. In most cases, this condition is normal and therefore should not be interpreted as a problem with the device.The device has a protection feature that if the device becomes too warm (due to use of GPS while charging, BT while charging, using the device as a wireless modem, etc), the auto protection feature will be triggered and the charging process will be stopped. Once the device cools down, the device will then begin charging again.
  3. Check the USB Port on the device for any bent or misshapen PIN's.
    • If some are found, that is the most likely cause and this is considered physical damage not covered under the Warranty.
  4. Remove the battery and inspect the contacts.
    • Remove any debris/residue found on the device or battery contacts with a soft, dry cloth.
  5. Look closely at the battery contacts on the phone to see if they are bent out of shape.
    • If they are bent, the device will need to be exchanged.
  6. Try charging the device (try different power sources as well as chargers):
    • Plug in USB to device and PC; is the LED indicating that the device is charging?
      • Note: If the device isn't charging while connected via USB to a PC, go to Start>Settings>More>Power>Power Management and make sure that "When device is turned on, do not charge the device when connected to the PC" is set to OFF.
    • Plug in AC Charger to device and outlet; is the LED indicating that the device is charging?
      • LED indicators: Charging is indicated by a solid Amber light on the upper Left side of the face of the device.
        • Note: If the battery is completely dead, the light will be a solid RED for a few seconds while it is charging; once the device has enough power to turn on, the light will turn to Amber.
  7. Try another Power Source.
    • Try a different outlet to rule out that as the issue.
  8. Try another battery in the device.
    • If another battery doesn't work, perform a Hard Reset.
      • If the device powers up after Hard Reset, test the unit for a few days. If issue returns, device can be considered for an exchange.
      • If device shows charging with one (AC Charger or USB) and not the other, issue is with the accessory. Replace accessory.
      • If device will only power up when attached to charger (AC or USB) it is likely the battery needs to be replaced.
Device won't hold a Charge
The life of the battery between charging sessions will vary depending on which features of the unit are being used.
  1. Verify the you are using:
    • OEM AC Charger
    • OEM USB Data Cable
    • OEM Battery
  2. Fully charge the battery using the OEM AC Charger
    • USB and car chargers are trickle chargers meant to get the user through until they can get to their AC Charger.
  3. If the device is not lasting the advertised Talk time, with minimal use, try another OEM battery in the device.
  4. If the battery life still is not meeting the advertised Talk time (with minimal use), the device will need to be repair/replacement.
Device won't Power on
  1. Attempt to charge the device.
    • If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens.
  2. Attempt to power the device on by pressing the Power Button for 3-5 seconds.
    • If the device doesn't power in, perform a Soft Reset using the stylus.
  3. If the device still doesn't power on, perform a Hard Reset.
  4. Try another battery.
  5. If the device still will not power on, it can then be considered for repair/replacement.
Handset Powers off
  1. Make sure that the device is actually powering off and not just going into hibernate mode by pressing the power button once.
    • If the screen comes back on, the device is not powering down.
  2. If possible, check the battery level by going to Start>Settings>More>Power>Power Management.
    • The charge should be no lower than 10%; if it is, charge the device and retest.
  3. Try another battery in the device.
    • If the device stays powered on with a different battery, the issue is with the accessory not the unit.
  4. If the device still powers off with another battery, Hard Reset the device and retest.
    • If the issue remains after the Hard Reset, the device it can then be considered for repair/replacement.
Nov 13, 2010 | T-Mobile Dash Smartphone
My Sony PRS600 does not fully charge. I had it
First, confirm whether you're using the AC-S5220EAC Adaptor to charge the Reader, as it's always recommended to use that one with the Sony Reader. However, you may also keep connected the Reader to the Computer for at least 4 hours to get it fully charged. If the issue still persist, perform a soft reset. To soft reset, please press the RESET button using a sharp-pointed object. Then, try charging it. That should resolve the issue.
Jan 26, 2010 | Sony Reader Touch PRS-600
The USB connected screen is frozen on my reader and I don't know how to fix it.
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred. Please perform the below mentioned steps and check whether it helps. Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure. 2. Perform a soft reset. Just press the RESET button using a sharp-pointed object 3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup. 4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again. 5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding. 6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset. 7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off. * It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E. 8. Once the Reader has sufficient charge, perform these troubleshooting steps again. 9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status: * You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged. * It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired:
Jan 02, 2010 | Sony Reader Touch PRS-600
HP Ipaq does not turn on
Ufortunately, the battery is likely the culprit.
You can try removing the battery overnight, then leave on charger for at least 12 hours.
These batteries generally require replacement every 1-3 years. They deteriorate quite rapidly if left unused/uncharged for extended periods of time (like a year!)
Jun 25, 2009 | HP iPAQ HX2490 Pocket PC
Zire72's on the fritz!
Plug the ac wall adapter to charge the PDA and leave it there.
When the PDA exhausted the battery charge, it needs minimum 30 minutes to charge to the minimum level to have the PDA powering on.
Once it powers on, leave it charging the battery until is fully charged (3-4 hours).
Best regards,
Sep 02, 2008 | Palm Zire 72 Special Edition Handheld
Phone is not working
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Aug 13, 2008 | HTC P3300 Smartphone
Will not start up after recharging the battery
Hello :-) I think that your battery is causing the problem. You might have charged you ipaq to many times with a cheap battery and the battery might be completely dead. Or the battery might just be defective.
Apr 12, 2008 | HP iPAQ H2210 Pocket PC
IPAQ H2210
yes I replaced the battery a couple of days ago.the align screen is frozen
Feb 23, 2008 | HP iPAQ H2210 Pocket PC
IMate JAM battery drained off
When I bought my Imate I had the same problem. Put the charger on it and leave it for an hour or so and check the results. Just so the backup battery gains charge.
Sep 07, 2007 | i-mate JAM Pocket PC
PDA Does not go on
Plug it in and use the soft reset. Wait 10 seconds and then turn it on.
Sep 03, 2007 | HP iPAQ rx1950 Pocket PC
HP iPAQ H2210 Pocket PC Logo
133 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
