Toshiba EStudio 223 Copiers Logo
ZAFAR ALI Posted on Sep 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to change papar orientation from landscape to portrait. I changed it in paper tray but paper orientation in printing does not changed. plz guide.
Xanda Frederica
Level 2:
Guru:
  • Toshiba Expert 183 Answers
  • Posted on Sep 30, 2013
Xanda Frederica
Toshiba Expert
Level 2:
Guru:
Answers
183
Questions
0
Helped
112270
Points
500
Dude, changing paper orientation on paper tray is just one step, while you must change paper setting on printer driver too. In some machines, you should change paper switch position too :)
1 Related Answer
Anonymous
  • 66 Answers
  • Posted on Aug 31, 2010
SOURCE: I have a Toshiba 2060.
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Canon imageRUNNER IR 6570. Help me please! I have copier machine canon ir6570. The problem is I can't change tray No. 4 to A4R or A3 paper size, it only detected as Legal size.
question edited for clarity and toss in some CAPS.
It doesn't take A3 Paper and doesn't have a Tray No. 4.
A4R is just A4 in Landscape Mode, half an A3.
What is A4 and A4R?
The "R" indicates that the paper is set in the landscape orientation. Paper that can be set either in the portrait or landscape orientation. Paper that can only be set in the landscape orientation. 8-1/2" × 11" A4, B5. 12" × 18", 11" × 17", 8-1/2" × 14", 8-1/2" × 13", A3W, A3, B4.
Tray Capacity No-collate Mode Tray A: 250 Sheets (Letter, Statement-R, Executive) 125 Sheets (Legal, Letter-R, 11" x 17")
Tray B: 1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (Legal, Letter-R, 11" x 17") Tray C: 2,450 Sheets (Letter, Executive) 1,700 Sheets (Statement-R) 650 Sheets (Legal, Letter-R, 11" x 17") Collate and Group Mode Tray B: 1,300 Sheets (Letter, Executive) 650 Sheets (Legal, Letter-R, 11" x 17")
Tray C: 1,700 Sheets (Letter, Executive) 650 Sheets (Legal, Letter-R, 11" x 17")
Staple Mode Tray B/C: 1,300 Sheets/100 Sets (Letter, Executive) 650 Sheets/
https://copiersonsale.com/wp-content/uploads/brochures/Canon-imageRUNNER-6570-Brochure.pdf
https://www.google.com/search?q=canon+ir6570+paper+size
Changing Tray Size Settings
https://www.google.com/search?q=canon+ir6570+change+paper+tray+size
Ricoh Aficio MP C3300
Go into the print driver and the machine settings and make sure the paper size and direction are all in agreement with each out and the paper in the tray itself. If screen icons do not agree with the size and direction of the paper in the tray you will have a lot of weird problems.
1helpful
Canon ir3045n - when printing the paper orientation has switched to landscape. How do we change it back to portrait?
Hello Donna,
To change the orientation of the printer from landscape to portrait follow these simple steps;
- open any document and go to print from the file menu
- when the printers settings window opens click 'properties'
- In the next up coming windows you can see menus like 'main, page setup, effects' profiles
maintenance etc.
- click 'page setup'
- There you can see 'page size' and 'orientation'
- change the 'orientation' from landscape to portrait
- click ok and print
Done : )
please rate if this solution was helpful for you, thanks you!
8helpful
For some reason our Canon Image Runner 2270 started printing in landscape versus portrait. We did not touch the machine and the printer setup shows portrait - I assume I have to change something on the...
Check your paper size/orientation dial on the paper tray you are using. I believe this machine uses this dial to tell the machine what paper size and orientation is loaded. Make sure the dial matches the size and direction.
1helpful
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
2answers
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
2answers
Simple Problem
On a typewriter, Roll the Paper in the long ways, On some word processors you can change if you have a screen.
Copier Orientation
clean the three paper selection sensors on the feeder.better you select the paper tray according to the paper orientation instead of using auto paper slect function
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
