I am getting application error 437 after running my recovery disk? What does that mean?
    Sergeant:
  • 239 Answers
It migth be due to...
1) This problem appears to be due to starting the computer incorrectly when using Ghost with GoBack on the computer. For instructions on using Ghost with GoBack, go to this link....
http://service1.symantec.com/SUPPORT/on-technology.nsf/docid/2001101715043525
2) This problem can also happen when you use a brand or type of CD that does not work well with your CD-R or CD-RW device. In this situation, Windows or DOS might be able to read information on the CD that other applications cannot. For information on this and other troubleshooting methods, go to dis link.....
http://service1.symantec.com/SUPPORT/on-technology.nsf/docid/2000101912131625
3) This problem can also happen when you use Ghost compression. To solve the problem, use a different compression rate or no compression.
Hope dis will solve ur problem....please rate the solution...
Posted on Apr 20, 2009
Error 437
It usually means "cannot read file" or something along those lines. You can try cleaning the disk, or making a copy with another machine.
If not you will have to find another recovery disk or a retail version of the Windows you are trying to install, which I suspect is XP.
Jun 19, 2012 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
My smartbook does not want to turn on because of a error saying '' Application explorer exe. error '' what should i do?
you can recover your windows by recovery disk (if you have a recovery disk, due to specification of your notebook, it's use windows xp which has built as your original os, it means your notebook has a recovery disk) but you will lost your data in drive C (drive contains your operation system)
turn on your notebook
press f3 immediately from your keyboard
select MSI recovery manager
press OK
wait until the process of system recovery finish
Jun 05, 2011 | MSI Wind U100-016US Laptop
Application error 437 - cannot read file 17274 bluesky.wmz This is first time I have tried to use the Toshiba recovery disk for my Satellite A45-S250. The installation repeatedly fails with the above error...
check the cd you are using for scratches, looks like a readom the cd error to me.
to solve:
copy cd using freeware program: imageburn,make an image of disk, burn it onto cd-r(your save-copy, legal)
try installing from copied version could work
else:
copy whole installation cd into sepearate folder and run installation from harddisk.
Jun 17, 2009 | Toshiba Satellite A45-S150 Notebook
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Used Recovery Disk and I have an application error
It seems like your hard drive has some bad sectors.
You need to run some disk manager software to check/fix tour disk.
The best choice would be to download the "ultimate cd" from here
Boot from the cd, go to "hard disk tools" and select a disk manager (better to select the one from the same manufacturer of the disk).
Run a scan, and fix the drive (if it is possible). Then rerun your system restore cd again.
If the hard drive can't be fixed, you'll have to replace it before running the system retore.
Dec 15, 2008 | Toshiba Satellite A135 Notebook
HP Pavilion Recovery Disks
Sounds like the HDD has failed. Install a new HDD and it should run with the install disks.
May 29, 2017 | Computers & Internet
Sound drivers for Xp sp2
For specific models with different chipset drivers, you can get the sound driver & pretty much everything else on support.toshiba.com. If you can't connect to the Internet, "Tecra, Portege", & sometimes "Qosmio" models came with a built-in HDD recovery, meaning you need to create your recovery disk by running the "Recovery Disk Creator". An application to create your recovery disk. A shortcut is created on the desktop by default, if you cannot find it there, try looking at "C:\Program Files\Toshiba\Toshiba Recovery Disk Creator" & run the "exe" file, it should give you a menu to create one. After creating the disk, you can use that disc to install the drivers for all Toshiba pre-installed devices/softwares on that machine. For Satellite models, the disc should come with the laptop when you boughtt it. When you have the disc, just insert it inside of windows, it will give you options to install the driver & software for a specific toshiba device.
Hope this helps.
Jul 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Continue to have windows not load after recovery, error
try getting a full copy of xp then use another application
like nero
if you need more advice on this get back to me
Mar 24, 2008 | Computers & Internet
Mce gives a decoder error after reloading system
Problem resolved
after loading the system , place Recovery disk 1 which exhibits all the applications need to be recovered.
Thanks
essar
Mar 04, 2008 | Sony VAIO VGC-RB42G PC Desktop
Error 437
Hi, I did a Google on your error 437 and it would seem that this problem pops up only if: 1. using SYMANTEC (Ghost); or 2. using Original Toshiba Restore Disc. where possibly: a. the restoration procedure needs to write a log file somewhere (A:?) which does not exist and therefore waits; b. the restore disc is probably corrupted; and/or c. the Ghost image is corrupted. A few things you can try: * On another computer, check the integrity of your recovery disc; * Get hold of another Windows installer and do a complete, clean, fresh install (you will have to use your original Win numbers @ the bottom of your laptop). You will only need the recovery disc for your hardware drivers; or * Call Toshiba Support and get assistance. I was made to understand that they provide replacement Recovery Disc (>50USD). Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Aug 27, 2007 | Toshiba Qosmio F25-AV205 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
