Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai pt 5598
I turned off the tv last night and this morning only the Red LED came on. I have done nothing to trouble shoot the problem. I saw a similar problem posted so I think that you may have the solution.
  • 2 more comments
  • eneg Mar 18, 2008
    I spent a lot of time looking for a replacement lamp for this tv only to finally find out that it has three tubes and no lamp. I finally called in a tech who "jump started" the tv (I saw the green light for a sec) then proceeded to tell me that it was the 'motherboard' and the cost for repair was $450 for the board and $100 for the install (cost for that advice $89). Or he would take the tv off my hands and give me $50 for it. Needless to say that it is sitting in my garage (mother board un plugged )untill I can find someone to give me a straight answer (when hell freezes over I am assuming)
  • artiev Mar 28, 2008
    We watched a movie on the TV via an old VHS video, turned the TV off at the TV, then later in the day tried to turn it on, but it wouldn't turn on. The red LED blinks several times, but nothing else happens. I called Akai who said that the TV was manufactured by Samsung and gave me the registered Samsung dealer. He told me it would be $100 to have it looked at and that the repair would likely be $200 to $500. Given the age and technology of the TV, I'd say it's not worth fixing if it might cost $500. Would be interested if anyone has any suggestions. Thanks.
  • Anonymous May 25, 2008
    I was watching TV last night ...when I woke up I went to turn it on ..I only saw the red LED light flashing.....and the TV won't turn on...
  • ardis8500 Jun 18, 2008
    I'm having a very similar problem, but I am getting sound. I tried unplugging the power plug on the convergence board, but it did not make any difference.
    This TV was a given to me from a guy at work. He had to have it calibrated once and then the picture quit. He had enough with it and rolled it into his garage. It's in mine now and I'd like to try and fix it. He told me that it had a great picture and was a great TV. Any other suggestions? Thanks!!
  • 3 Answers
Found this part at tiger direct for $75.95 worked perfectly!
here is the address http://tigerdirect.partsearch.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Posted on Jul 23, 2008
The Solution posted by "Guest" on March 18 2008 worked exactly as he said it would. The part was delayed a week or so due to back order, but it arrived yesterday and, once installed, fixed the problem for under $100. THANKS "GUEST"!!!
Posted on Apr 16, 2008
I second the post from Guest on march 18, 2008. I ran into this page and this was the exact problem i had. I thought, i should try this given the other solution, meaning calling in a professinal for 300 dollars. Anyways, the part Guest said to order worked perfectly. I installed it myself and it was easy. Took about 2 minutes. The works great now. And that website is really reliable. If the part you order ends up not working, you can return it for a full refund. Good job Guest, you just saved me about 300 dollars on repairs!!
Posted on Jul 10, 2008
I had the same problem with the same model i bought at an auction and it ended up being the convergence board it is the board that looking from the back of the tv its on the right and mounted with one screw and has two stk 040 black modules on it to see if this board is the problem unplug tv take lwr back off and unplug the red connector which is the pwr connector to the board it is located clear on the left side facing the back of the tv carefully plug your tv back in and try to turn it on if it comes on this is your problem ps never mess around anywhere inside your tv with it plugged in always unplug first. good luck if this is your problem you can get the part at partstore.com part#bp95-00142p for about $75.00 dollars
Posted on Mar 18, 2008
SOURCE:
Akai pt 5598
So the screen shows nothing, you just see an LED? It's likely just a burnt out bulb in the projector lamp. These should be easy to check and replace, it's really no different than changing a lightbulb in a lamp.
Sep 21, 2007 | Televison & Video
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
AKAI PT 5598 HDI blurry with too much red color in picture.
T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
Dec 09, 2017 | Akai PT5598HD 55" Rear Projection...
Tv won't turn on
I had a similar problem when there was a power outage or the lights went briefly out. I unplugged the TV and left it for a few days/weeks and then plugged it in and the TV worked. I think newer TVs should be treated like a home computer and put them on surge protectors.
Jul 08, 2008 | Televison & Video
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
Describe your Akai PT5598HD 55 in.
looks like you have a convergance problem akai is made from samsung
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
Green is not being displayed on my TV
If you have experience troubleshooting solid state TV sets, you should be able to tell by a couple of voltage measurements if its a problem with the picture tube or the drive circuit. Simply take the multimeter and compare the base voltage of the green drive to the red or blue drive transistor. If the voltage is about the same, measure the collector of all three. if the green voltage on the collector is higher then the others, then theres an open between the drive transistor and the crt element. this could be an open resistor, a bad solder connection on the crt socket, or an open picture tube element. If theres no voltage there then your going to have to trouble shoot the drive circuit.
Sep 08, 2006 | Toshiba 32AF41 32" TV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
227 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
