Question about Refrigerators
Fridge and freezer not getting cold hot point fridge
  • 544 Answers
HI,
if the compressor is running your ref. should be getting cold.
Their is a defrost timer but when it is in defrost the compressor shuts off.
I think you do have a leak.
thanks,
Posted on Apr 20, 2009
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
Why is the fridge part of my hot point not working when the freezer is
There is a fan that pushes air from the freezer to the refrigerator, the fan could have ice in it or the whole freezer could be iced up Check for air flow in the refrigerator. Try defrosting the freezer.
Aug 31, 2014 | Refrigerators
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Hot fridge - cold freezer
Hi. I reccommend you replace the defrost timer and bimetal thermostat. The bimetal thermostat is located on the evaporator coil. The bimetal thermostat is the most common failure. Good luck, Mack
Aug 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge freezer unit keeps frosting up
HOT POINT REFRIDGE FROST APPEARS IN FREEZER. FREEZER NOT GETTING COLD. HAVE TO DEFROST AND WILL WORK OK FOR TWO WEEKS
Jul 30, 2008 | Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Hot point Fridge/ freezer
All the cooling is in the freezer and the control in the fridge side only controls a damper to let in cold air as needed. To do what you want you have to replace the thermostat to a lower temp rated unit
Nov 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
190 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
