Question about Victorinox Companion Swiss Army Knife from Knives
How do I disassemble my Victorinox companion knife?
I need to disassemble my knife to add a new blade from another broken model of the same type, but with a good blade.
How do I open range top
Need to know makwe and model but there will likely either be starps and screws at the back or hidden latches undere the top which you need to find and release with a dull knife blade or a spatula or a putty knife type of a tool.
Sep 21, 2014 | Kitchen Ranges
9" electsric knife EK700
Sounds like the small cam that drives the blades is broken...and any resistance to it stops the blades from moving. Use a phillips head screw drive to open the knife and inspect the drive cam. It can be replaced if broken.
Jim
Mar 10, 2014 | George Foreman GR10AWHT Indoor Grill
How do I change the blades on a vermeer 1600A chipper
Place the chute over the rotor. Remove all the clamp bolts for one blade. This will allow you to remove the old blade and clamp bar. Clean clamp bar and blade slot. Install new blade with clamp bar. You will need a knife gauge for this. Use the knife gauge at each end of the blade. Torque clamp bolts to 280 ft. lbs. After blades are installed it is necessary to adjust the bed knife by loosening the three bed knife bolts. Use the set screws to adjust the bed knife to 1/16 in. above the lower feed plate. Torque the bed knife bolts to 250 ft. lbs. Then use the other two bolts to adjust the lower feed plate to .013 to .016 between the bed knife and the rotor blades. Put the chute back into place and you are good to go.
Dec 08, 2011 | Garden
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Jun 02, 2011 | Stanley Utility Knife
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Remove oxide stains from a pocket knife blade
you could try a very weak solution of acid and water mix making sure not to scratch the blade, when the stain is removed smear a film of light oil over the blade hope this helps smirf617
Jun 02, 2009 | Victorinox Swiss Army Tinker Pocket Knife
Victorinox Companion Swiss Army Knife from  Knives Logo
1,809 people viewed this question
Top Victorinox Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Victorinox Boating Expert? Answer questions, earn points and help others
